Hyper Sports PCB
jonhughes
1,156CR
Can anyone help me fix a Hyper Sports PCB please? I am trouble shooting a board with graphics corruptions and I think the chip at 12C is bad. The corruptions are shown below.
I have tried to burn an EPROM chip at 12C from a MAME ROM set (which I think is the correct one). When I do the graphics corruptions improve slightly (and significantly on the Title Screen) but the problems are still there on other stages including a hit detection problem on the Horse Vaulting stage. I know that the data or the way I am burning it is not correct or I'm missing something because when I burn one of the program ROMs in the same way that I'm burning this graphics ROM the board dies.
Is there something different about these mask ROMs?
Purity
The Oracle
17 (100%)
2,999CR
I hope I'm not sounding obvious here, and forgive me if I am but these boards are notourious for having bad sockets. I had to change at least 6 sockets on a board I looked at recently.
Have you tried pressing down on the roms with the board powered up to see where the issue might be?
jonhughes
1,156CR
Hi Ben,
There’s definitely something wrong with the 12C chip. If I can sort that out it will either fix the problem or allow me to move one. I have even considered putting all the extra sockets in and using the standard EPROM sets but not there yet.
Purity
The Oracle
17 (100%)
2,999CR
C11, 12, 13 and 14 are shared gfx roms according to the schematic, so my suggestion is that you have a timing issue between the roms. I've seen things like this before. Can you replace all those roms with the same speed roms, and see if that improves the situation?
Purity2021-05-18 21:34:18
cliff_poole
1,069CR
That looks like a super mint condition board.
If you read all the ROMs do they compare exactly to the MAME set ?.
I have found it is easy for the odd chip leg to get bent up underneath the chip on those sockets, so worth removing the new ROM again and checking.
jonhughes
1,156CR
Unfortunately, the programmer won’t read the mask ROMS. When I read the same ‘working’ three mask ROMs I get the same error message on one of the pins but a different error message for the 12C chip - ‘no chip in reader’. If I burn any of those ROMs in the graphics bank I get odd graphics. If I take the original 12C chip and leave it in or take it out it gives the same faults.
Ace`
PlanB contributor #1
40 (100%)
4,040CR
Are you sure the maskroms are standard pinout? I remember changing maskroms on a Jackal board and some hackery was required as the maskroms didn't have a pin compatible eprom available.
Also using cmos chips (2764 vs 27C64) can cause issues although I haven't seen that too often.
Purity
The Oracle
17 (100%)
2,999CR
ah ok, C12 is only part of the rom. You need to burn to a 27128 and combine roms, as discussed here
http://www.ukvac.com/forum/hyper-sports-repair-log_topic357733.html
copy /b file1+file2 targetfile
so try:
copy /b c12+c11 targetfile
Purity2021-05-18 22:52:41
TheDaddy
14 (93%)
7,230CR
Yeh Ben correct i have done a few of these. Roms are 64 as some boards were populated with 64's but most were 128 so you need to merge them. I used my software to join files but plenty of software out there that will do it.
Dave.
