IC ID for Phoenix HElp?
Judder
931CR
Hi guys (Hi Paul!)
My Taito one has the daughter board on it and there's some pretty good shots of it here
Bring out your Phoenix
http://www.ukvac.com/forum/bring-out-your-phoenix-boardsets_topic346283.html
I can measure all of the resistors etc when I'm in the office next week where it is if that helps and then can add to your schematic Sarj
Regards
Alex
Judder
931CR
Here you go Sarj
Hope your eye sight is pretty good as the soldering is a bit dodge to say the least and my handwriting shows obvious signs of using a keyboard all day long
It's an original Taito part interestingly - PN07003
Resistors
- 120 kOhm (Brown Red Yellow?)
- 1 kOhm (Brown Black Red?)
- 100 Ohm (Brown Black Brown?)
Capacitors
- 7.5uF (fat green ones)
- 26pF (tiny one)
Transistors
- C1815 (link to datasheet)
3 of the legs on the bottom are joined by solder (middle 3 on one side, pins 4, 5 and 6)
Wires go to legs 1 and 12
Judder2015-10-26 20:05:23
