ID this chassis?
gunblade
9,085CR
not sure of model but i think hantarex eq series, this should be pinout
virtvic
The Cabaret King
21 (96%)
2,012CR
I found the manual - it's an MGG 15" EQ/2 HR
I was hoping to use it with a tube I recently got from an old Bush tv with a Chungwha tube.
I don't see the regular 4 pin yoke connector on the chassis, so I'm thinking this thing needs a fancy tube?
virtvic
The Cabaret King
21 (96%)
2,012CR
Of course they do! I was looking for a 4 pin thing like the TV I took the tube from. I’ll have to work out the yoke wires to the Hanty green plug. The 2 middle wires on hanterax are joined?
cools
I joined ages ago honest
19 (95%)
798CR
IIRC its compatible with the tube and yoke of the NOS 17" that popped up recently. I've got the same chassises (chassii?) and tubes and was messing around a while back
virtvic
The Cabaret King
21 (96%)
2,012CR
I have wired the 'new' tube to a salvaged hantarex coil plug which will go into the MGG15 chassis. Is this correct before I try it out and potentially kill both tube and chassis?
The green plug was taken from a dead Polo 2 tube.
gunblade
9,085CR
yes looks ok
red and green at hanty 6 pin should read about 2 ohms
blue and brown around 7-10 ohms
you can also check by looking solder side as horizontal winding will go the HOT collector and to lin coil
virtvic
The Cabaret King
21 (96%)
2,012CR
Doesn't seem to work. All I'm getting is a very small (about 5mm) orange/red line in the centre of the screen. Can't see any neck glow either?
gunblade
9,085CR
probably need to match the heater resistor for a start
need to see solder side of chassis
how do you know the chassis was working before you installed it?
virtvic
The Cabaret King
21 (96%)
2,012CR
That's the thing. I was given the chassis YEARS ago. I was told it was from a monitor that got necked. It is brand new as far as I know, but who really knows?
I was just hoping I could make another monitor out of a spare chassis and a free old tv, but as per usual, my luck sucks...
I'll see if I have a hanty chassis laying around I could try with the tube.
