Image horizontal squeezed
Isgoed
47CR
Hello,
I have a Pentranic 27"monitor with a CH-288 chassis.
The image is horizontally squeezed, equal on both sides.
When changing the H-sync pot the image is just a little wider (scrambled of course).
This occured after I tweaked the pots on the remoteboard for the h and V size and sync, everything worked good, but after half an hour the screen suddenly went like this.
I've resoldered some dry contacts, measured the resistors in the width circuit and everything seems ok.
The width coil has been untouched by me, I replaced all of the caps like 2 years ago.
I also tried a different remote board, no luck.
Also tried and changed the 5K pot for H-sync for a 10K, and with this I can stretch the screen a little wider.
Is there a part that can cause this all of a sudden, or has the flyback gone bad?
Isgoed2020-11-09 18:03:35
Isgoed
47CR
gunblade said:
does the horizontal size pot do anything?
Yes, this works as it should, I can adjust from smaller to big image.
It's just as if the maximum width of the screen is reduced.
And I must rectify, it wasn't the H-sync pot that I've changed with a 10K pot, it is the H-size pot.
Isgoed
47CR
After placing my question, I left the monitor working as it was.
Two weeks ago, I took the chassis out for another inspection and also took out the small pcb mounted near the flyback for a closer look.
I had checked everything on the chassis before, except -very stupidly- this board.
This is the switchboard that has the connections for 15K or 25K usage.
Turned out that there were several solder/pinpoints that were loose badly, so I cleaned them up and resoldered, resulting in a good working monitor!
My other cab has the same monitor, so I took out and resoldered that switchboard too, in case that one could have given problems in the future.
Maybe this might be of help for someone who faces the same problem with a 27" dual sync CH-288 Pentranic monitor.
