Image orientation
davey d
480CR
Does anyone know if it is possible to flip the image on a Toei monitor in a Taito cocktail cabinet?
Ive recently picked up a Taito cabinet which had Moon Cresta in it. When paying this game the orientation was correct as you sat at the table.
I have since tried some Jamma games in it, and they are all the other way round (have to sit on the player 2 side)
Is there a way on the chassis to flip the image, or is my only option to spin the tube around (as long as there is enough cable slack for the flyback, and neck board wires)
Fantazia2
2,246CR
Check the dip switch settings for the Jamma boards as some of them may have a screen flip option.
I know that a 1942 boot and a Raiden Fighters boards I used to have had a dip switch that flipped the screen round.
davey d
480CR
jinq-sea said:
Can you swap the yoke connectors over? I know that works on Nanao stuff!
I'll have to have a look. I think the plug is 1 moulded unit, so may involve cutting the plug up depending on how the wires are configured in the plug.
Ive always presumed that on a CRT the flyback does into the tube at the top when its in the horizontal position? on this setup the flyback goes into the bottom when running a horizontal game
davey d
480CR
Just done another google search, and have come across this which is quite handy:
http://www.crtsolutions.com/CRTSafety.pdf
Looks like i would have to do a vertical reverse, and a horizontal inversion.
Is the colour scheme for yokes a typical standard? Red + Blue for horizontal. Yellow + Green for vertical?
davey d
480CR
Finally went for it today. Found the plug, but the design of it wasn't possible to split the plug, so I decided to swap round the connections in the plug. A few seconds with a pin extractor, and all the connections were out of the plug. Swapped round both the horizontal, and vertical and now it's rotation is how I need it :-D
