important info for chassis repairs
gunblade
9,130CR
mods if you want to move this be my guest
important notice to anyone wanting monitor repairs
I am no longer willing to take chassis for repair that have had attempted repairs
gunblade
9,130CR
this applies to people that have knowingly messed around with a chassis-I have recently had a few chassis from people and the work to put things right is too much
DABYX
109CR
What about if there has been caps and flybacks installed and working, then a failure without attempting repairs?
I understand how it must be a nightmare though!
gunblade
9,130CR
it doubles the time of the repair and people do not want to pay double repair cost,so don't attempt repairs unless your soldering skills are good
I have caps reversed,wrong values,resistors wrong value,crap flybacks-you name it
runkthepunk
19CR
I actually have at least two chassis that I need repairing but have no idea if they have been messed with before.
Maybe if people can provide detailed pictures first that will stop you having to reject/return boards?
I'm going to PM you now regarding my chassis.
pobtastic
477CR
I can second this, when I used to do repairs you make a base assumption that the items (PCB's in my case) were working previously and you measure and test accordingly for faults. There's nothing more frustrating than spending ages looking and then finding that there are chips in back to front, chips in the wrong places, etc, etc, etc ... I've seen it all! It's why I stopped doing repairs as well, it simply takes too long and then people grumble about the cost.
obcd
3,830CR
Attempted repair means that there was messed with the chassis after it broke. I assume any prevoious succesfull repairs don't fall under that category.
Indeed, wrongly installed capacitors or resistors with the wrong value is not something you are expecting during fault finding.
obcd2017-02-09 12:58:54
RGP
Meeter & Greeter
2,039CR
This goes the same with PCB's as well. I've had a few through with some botched attempts at desoldering stuff - slows things down massively.
With monitors, I still send non-starts to Gunblade, something with a general picture fault i'll follow the schematic and see if I can find the problem.
