In Game Menu
tazfaedodge
91CR
Seen a video of a Neogeo with the uni-bios on it running and wile the game is playing (or at least running the demo) someone was able to access a menu and change settings like time outs how hard the game play is etc.
How the smeg do you get into this? And does it only work with real games and not the ??? n one carts?
Nck
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
the unibios is a chip that plugs into the NEO GEO motherboard
it replaces the current usually socketed bios
i use it with a 161in1 and it works fine
not officially supported but works spot on
if you need one i can provide
http://www.ukvac.com/forum/topic338003.html
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
[size="+1"]HOW IT WORKS[/size]
The UNIVERSE BIOS is a patched version of the original SNK BIOS. Most code is the same as the original
BIOS with the new code being worked into it. To access features of the UNIVERSE BIOS you will need to use button codes.
These codes can only be used on player 1 controls apart from the controller test code.
The following codes should be used while the splash screen is showing or held during power up if the splash screen is disabled;
Code:
[b]     [size="+3"](A)+(B)+(C)[/size]		[/b]UNIVERSE BIOS Menu[b]
	     [size="+3"](A)+(B)+(C)+(D)[/size]	[/b]Memory Card Manager[b]
	     [size="+3"](B)+(C)+(D)[/size]		[/b]Test Mode (MVS only)[b]
	     [size="+3"](B)+(C)+(D)[/size]		[/b]Hardware Test (AES only)
The following code can only be entered on player 2 control
Code:
[b]     [size="+3"](A)+(B)+(C)+(D)[/size]	[/b]Controller Test (AES only)
The following codes are available in game only;
Code:
[b]    [size="+3"](START)+(SELECT)[/size]	[/b]In Game Menu[b]
	    [size="+3"](START)+(COIN)[/size]		[/b]In Game Menu[b]
	    [size="+3"](START)+(A)+(B)+(C)[/size]	[/b]In Game Menu
silverfox07862015-12-09 22:24:11
