Initial D 3 Volume
mickyc22
67CR
Im after some advice on ID3
i dont have the service board/coin tower so manually attempting to wire up the external harness.
I've worked out the service/test and degauss switches
but im struggling on the volume, i can get the front and rear speakers working but only on full blast, can anyone assist me in how to wire them up so they can be adjusted, i've done this before on the like of Daytona etc with no trouble but i just cant figure out how on this.
if it helps these wires below are the ones from the amp that go to the harness
Many thanks
bbz149
26 (100%)
1,608CR
Rears Speakers? Thats a 2 Channel Amp! IIRC ID3 does not have rear Speakers fitted, the Grills are there but no Speakers. I had to install a pair in mine and a 4ch Amp with Volume Pots to get rear audio!
mickyc22
67CR
Thanks for the reply, yea mine does have rear speakers in the seats, i can get the front or the rear or both blasting, i never installed the rear speakers i just assumed they were standard.
bbz149
26 (100%)
1,608CR
Yeah the will be load without the Volume Pots installed! I just got a small Plastic Box and installed 3 Pots, for rear, front and Sub as I had a 4 Channel Amp and Sub Amp. If nobody beats me to it ill take a look at the Wiring diagram as I cant rem of the top of my Head how I wired it up. You will prob just need to install 1 pot to the Amp
bbz1492020-10-12 17:56:20
mickyc22
67CR
i've tried wiring pots to what i believe is correct pins but no joy
this is the wiring diagram i have, im starting to wonder if im missing some jumpers on my amp and therefore its not configured correctly
robotech
823CR
Ive done a few of these but all 4 channel amps
I usually go from the connector that the
Credit board goes into
Then delete the switches coin counter and coin tower and just put the volume pots in a box for front/ rear / sub ajustment
It should just work with volume pots wired to the header pins you need the right resistance pots though
bbz149
26 (100%)
1,608CR
Gary, AKA Outrun2 is your Man for the Jumpers ETC. I rem he posted how to wire a 4Ch Amp a few Years ago, cant rem if it was here or J+
Ill pop up in the Loft tomorrow as I have a 2 channel Amp up there collecting dust and ill post a pic
bbz1492020-10-12 20:54:15
Outrun2
Colonel Outrun
1,183CR
CN2 on the amp are the volume pot pins. Going from memory a bit here but pins 1-3 are for front speakers, 4-6 are for rear speakers and 7-9 are for the sub woofer, via a low pass amp that you don't have.
So your wiring looks correct for an iD cab that has front speakers as stock. Pins 4-6 are wired on an iD cab through the red 18pin AMP-UP connector at the back of the base and right up to the VTS credit board, but aren't used.. handy if you have a VTS board and associated looms though as it makes this easy.
If no pots are wired you should get no sound at all out of a Naomi or Chihiro.
The jumper info, along with all the info on wiring 4ch amps is documented in my thread on AO. Fortunately I put it on there as most of my Sega driver info was on J+ and is now lost forever thanks to it's wonderful 'owner'
I would concentrate on getting one set of speakers working, front preferably, before you worry about non stock setups. To independently control volume for front and rear you will need a 4ch amp. You can link the volume for four speakers to one pot but it won't be great as the rears will be too loud as they're right by your ears! Can't remember off hand what the jumper settings are to combine volume to one pot, but for sure you don't need any jumpers set for a standard one pot, one pair of speakers setup.
Make sure you are using the correct 5k pots, and they're wired the right way around.
mickyc22
67CR
Many thanks for the info outrun2
Something is weird about my setup so pin 2 seems to be the active pin and no matter how I wire it up using a 5k pot its always full blast either on the front or rear
