ISO transformer
r-type
633CR
Afternoon all,
Can anyone confirm whether this is a suitable ISO for using with a WG19K7000 and also a Hanty MTC9000?
Input voltage for the K7000 is 120v (+10% -15%) and the Hanty is 128v (+10% -20%).
https://uk.rs-online.com/web/p/din-rail-panel-mount-transformers/2787074?cm_mmc=UK-PLA-DS3A-_-google-_-PLA_UK_EN_Power_Supplies_%26_Transformers_Whoop-_-DIN+Rail+%26+Panel+Mount+Transformers_Whoop-_-2787074&matchtype=&pla-299641525097&gclid=CjwKCAjw34n5BRA9EiwA2u9k3xf7I0tRNK8ZxjaBBUhLuwn77z-VnGo2LwAGgRCeI75ZI5vVv92aCBoC0gEQAvD_BwE&gclsrc="aw.ds
Flinnster
The Dino King
29 (100%)
2,566CR
Hmm.. yeah it's primary is 230.. so if you're nearly 240 at the mains in your location you'll actually be getting 120V out. The VA rating will matter however... it's 100VA. I've no idea if that's enough - airlink's cheapest single stepdown is 100VA rated, but their lowest dual plug out is 750VA.. (so 375VA each?)
Flinnster2020-07-30 13:04:45
simonden
20 (100%)
1,042CR
Block ISOs are really good, my go to for monitors (and yes are proper arcade ISOs).
The one you have linked to, you are paying a bit more for the case (not needed) and has screw terminals.
This is the one I use, cheaper, and uses spring terminals, you will need to connect the 2 outputs in parallel to get the full 100va:
https://uk.rs-online.com/web/p/din-rail-panel-mount-transformers/4197423/
simonden2020-07-30 13:20:09
r-type
633CR
Thanks for the replies chaps. The Hanty manual says it needs 100VA but can't find anything that says what the K7000 needs unfortunately.
I would have thought it was similar.
I've just metered a socket and that was showing 240v so thanks for the heads up there.
simonden
20 (100%)
1,042CR
They also do 160va and 250va
I looked this up a few years ago and 90% of 19/20 inch monitors are fine with under 100va and the the other 10% was was just over the 100va so needed the 160va. Can't remember which one's off the top of my head. Most of the 25+ inch monitors needed the 160va.
EDIT: Just checked the manual and the 100va is fine for the k7000 19 inch (which is max 85w). Just remember that each of the 115v outputs will only provide 50va so you need to run both outputs in parallel.
simonden2020-07-30 14:29:03
