J-Pac help
JonnyG
140CR
Been a while since I turned on my MAME cab but went to it last night and for some reason the sync lights on the J-Pac weren't lit and obviously there was no image on screen. Looking at device manager I can see there is an issue with a USB HID device which states
This device cannot start. (Code 10)
An unknown item was found in the report descriptor.
This also appears if I remove the J-Pac and connect it to a different PC.
Has anyone got any skills in diagnosing / fixing these? It the 2nd version with the PS2 connectors providing power and a second port to connect an external keyboard.
Ta
JonnyG
140CR
UPDATE
Dismantled everything, unplugged my JAMMA 2 MVS adapter and rebooted a couple of times, with just the J-Pac connected via USB and now have both Sync In and Sync OK LEDs on, still have the error flagged in device manager however.
Might just give it a good scrub with IPA and possibly touch up all the points next time I'm in the vicinity of my soldering gear.
I can only really assume though unless the above miraculously sorts it out, that it's on its way out. Still very interested if anyone has any thoughts though.
Cheers.
big10p
Coins detected in pocket!
6,086CR
So, do you have an image on the monitor now? Were you able to test if the controls are working? I've managed to kill a couple of jpacs so that I get video, but no controls.
JonnyG
140CR
Yes, at the moment image and controls are working, the only thing that bothers me is the why it decided to do it in the first place and the error message in device manager.
I had a V1 J-Pac where a similar thing occurred with sync but that was when they had a big fat removable IC and Andy at Ultimarc basically said it was toast.
JonnyG
140CR
UPDATE #2
After a reboot getting no sync LEDs, remove and reconnect USB to various ports, both sync LEDs, then I lose sync OK after a few seconds.
Grrr.
