J-Pac sync issues
RygarR
<div class="bbWrapper">Hi Everyone,<br /> <br /> Had my two MAME cabs fired up a fair bit over the hols. Both are based on MAMEd PCs and J-Pacs. While I&#039;ve had them on for hours on end previously with no issues, the J-Pacs on both of them are now periodically losing sync. The time it takes for this to happen is fairly random, and the effect varies. Could be, they&#039;ll last for 2 or 3 hours with no probs at all, and sometimes it&#039;s just the Frontend screen that gets lost, with the games themselves syncing up OK.<br /> <br /> I&#039;ve read elsewhere on the web that this might be a voltage issue. And right enough, I have mucked about with the USB ports and the stuff plugged into them over the past couple of months. <br /> <br /> I was wondering though, if it would be possible to use a Y connector to link the J-Pac and PC with a separate USB power adapter? Or would that risk shorting or blowing components?<br /> <br /> Any advice welcome...</div>
minwah
<div class="bbWrapper">What do you mean by &#039;losing sync&#039;? Are you talking about the monitor / video signal? <br /> <br /> If so, how are you making your video 15khz...ArcadeVGA or Soft15khz or similar?</div>
RygarR
<div class="bbWrapper">Hi Minwah,<br /> <br /> I mean that the image stops being stable and starts to roll as if the vertical and or horizontal synch pots have been twiddled - which they haven&#039;t. I&#039;ve tried adjusting the pots when this happens, but nothing happens<br /> <br /> I&#039;m using software solutions for both. One is Soft15Khz. Pretty sure the other is on CRT emu-driver.</div>
minwah
<div class="bbWrapper"><blockquote data-attributes="" data-quote="RygarR" data-source="" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch"> <div class="bbCodeBlock-title"> RygarR said: </div> <div class="bbCodeBlock-content"> <div class="bbCodeBlock-expandContent js-expandContent "> Hi Minwah,<br /> I mean that the image stops being stable and starts to roll as if the vertical and or horizontal synch pots have been twiddled - which they haven&#039;t. I&#039;ve tried adjusting the pots when this happens, but nothing happens </div> <div class="bbCodeBlock-expandLink js-expandLink"><a role="button" tabindex="0">Click to expand...</a></div> </div> </blockquote><br /> It sounds a bit like the v-hold, but if you&#039;ve tried that...<br /> <br /> Does your JPAC have the sync led&#039;s on it?<br /> <br /> I think to rule out the power problem I would get a powered USB hub to go between PC and JPAC, and don&#039;t plug anything else into it.</div>
RygarR
<div class="bbWrapper">A powered USB hub. I didn&#039;t realise there was such a thing! Sounds ideal though. I&#039;ll give it a try.<br /> <br /> Cheers<br /> <br /> PS. When the frequency goes haywire, so do the sync LEDs on the jpacs.</div>
