Jamma extender
Danscu
257CR
Hi guys
Can anyone recommend a jamma extension harness which doesn't cause noticeable input lag? Reason is I need to test lots of jamma games and dont want to wreck the original jamma connector.
Dan
Titchgamer
123CR
Yeah you should not get any delay on any harness really unless the wires are stupidly long I don't think!
But I have used 3 of the AWUK ones Daddy has listed above with no issues.
6,093CR
I've had the AWUK one hooked up to a J-PAC on a MAME cab for a few years, without a problem. However, the J-PAC doesn't use any of the JAMMA voltages, so I would definitely consider changing the power wires (and ground) as stated above, if you want to use it with a game PCB.
Danscu
257CR
Many thanks guys
Sbdesign
SEGA collector
1,724CR
I know people have said no issues. I have used one that wouldn't boot a model 2 board, but fine without.
Maybe model 2 very fussy, and I was suffering a slight lower voltage. Can't remember the ins and outs of what I concluded at the time now.
But thought it is worth adding the info to the topic. Maybe useful to someone in some point of time reading this.
5,332CR
I wouldn't worry about signal lag in lengths of copper wire, unless you're planning on making the harness the width of the Atlantic ocean.
Model 2 has a sh*tload of 5V/0V power wires, so I'm presuming it draws a lot more current than a typical JAMMA board - someone should measure it. So with that, there might be plenty of scope for voltage drop due to bad contacts, weedy wiring and an inadequate PSU.
FrancoB
1,040CR
I wouldn't expect any lag from an extension as electricity travels at ~300 million meters per second.
What I would be concerned with is the wiring on 95% of the pre-made JAMMA extensions out there. They often don't fully connect all of the power wires and often use one or two 'thick' wires that are actually just thick insulation with a thin copper core.
Here's a 'good' example of a sh*tty chinese one:
You could buy one like that and then solder on some extra power wires or buy a decent ready made set like the [Arcade-Projects Jamma Extensions].
FrancoB2020-06-03 18:24:49
FrancoB
1,040CR
I've just seen the one TheDaddy linked to, that one looks decent for the money as its fully wired.
Another option is to make your own if you've got the bits. They're very easy to make, just a bit time consuming. If you've not got the bits, then to be honest, I think you would struggle to buy the parts for less than the one linked to, let alone factoring in the labour time.
