Jamma to MVS Multislot
neoretro
1,121CR
Hi all,
I really should know this. But what’s the quickest way to convert a Jamma edge connector to an MVS multi-slot?
Currently got a U4 running Jamma but would like it back to original and then just use an adapter to get it back of Jamma, which I already have.
Cheers all
Dave
TWB
318CR
I'm not sure the one on eBay is the right way round but I could be wrong.
I think you may need something like a JNX Big Red Adaptor, they sometimes come up on US eBay or you could try a wanted add.
Thefuzz73
27CR
i picked up a JNX big red adaptor and haven't used it i dont mind passing on if you need it.
so this adaptor is to connect a jamma board into an mvs wired cabinet just to clarify.
ta.
neoretro
1,121CR
ta.
Thanks but that’s the exact opposite of what I’m after. I’ve actually already got one.
I want to put a 6 slot in a Jamma wired cab
8,292CR
yeh i got the jnx etc...
yes it is jamma to mvs
seller has it in works with 2, 4, 6 slots
i’m not sure about game selection etc..
as i have not gone that far into it. yet ( got a 6 slot and u4 mvs 25
project on the go...)
i guess you need to look at pinout for mvs 2, 4 slot /6 slot and see if the game select is on the jamma edge
or one of the parallel side ide type sockets ?
8,292CR
thanx penros
is that the standard positioning on a jamma wired configuration?
sort of like this
mvs on jamma
p1 button 5 =select up
p2 button 5 =select down
Velyks
100CR
Solder button D into pins C and 25
Solder a game select button to either D or 26 (or both)
Solder right speaker + to 10
Solder left speaker + to L
Solder both speaker - to ground
Done.
8,292CR
yeh
or get a small amp
take stereo off the neo pcb headphone
or side pins. to small amp , wire speakers to the amp
take 5v from jamma edge up to the amp..
