Jon-A-Tron
I've mocked up a prototype JAMMA-to-SCART adapter. I've seen a few of these things available for about £20 on ebay, but I had these bits lying around and the circuit isn't very difficult.
500ohm Pots for RGB. Each set to approx. 220ohm.
500ohm Pot (all I had) inline with 220ohm resistor for Sync.
2 x 220ohm Resistors in parallel for 110ohm to pin 16 for auto switching to SCART.
Runs off to a Male SCART Connector on one end and a JAMMA Finger Board on the other. Finger board passes other connections through to JAMMA connector.
Here it is connected to the 19-in-1 Board.
Here's the result so far.
Display is a little small. I think this is the SCART Tv set to 16/9 with black bars top and bottom. Don't have ability to change this but I have ordered a remote to see if that fixes it.
Slight flicker on the screen which might be linked to the Sync Pot/Resistor line. Need to order a 1k Pot and replace in my next build. I've seen both 330ohm and 1k ohms used in the circuit diagrams I've used. Playable as is though.
Does anyone have a link to a PCB prototype manufacturer to get a proper PCB made for this? Anyone know who made the JAMMA fingerboards that I used here?
JT
JT
