Joining in Hyper Olympic/ TnF fault
vib_ribbon
488CR
i see that there's a lot of Track n Field related tech questions lately so i thought i might revisit this one which i've had for a while.
the game itself was working fine when i had it, and for some reason i decided to reset the high scores and that's when the problem started.
the graphics and the sounds, all seem to work fine, except when sometimes i'm on the long jump stage, when i'm doing my run up and i push the jump button, the character does not jump, instead he squats at the bottom of the screen and the game registers a foul. because of this the level cannot be beaten.
ps- i've found the video i made to show this fault.
any ideas what might be causing this? i assume it's to do with the code rather than anything else?
thanks.
shoestring
159CR
Hard to say.
If it only happens sometimes then its most probably a hardware fault.
Software issues are usually more consistent.
But you should still check for valid code on the 5 EPROMS regardless as part of your troubleshooting.shoestring2015-08-11 11:27:39
vib_ribbon
488CR
shoestring said:
Hard to say.
i will read them back in and double check the checksums, thanks.
yeah, it's a strange one. just as i think i might have fixed it by reflowing some pins or brushed up on some legs, it will resurface.
RGP
Meeter & Greeter
2,039CR
That definitely looks like a code execution issue to me.
Running, press jump, different action happens.
Action that should happen:
Show the angle meter - happens
Start the animation to move the character through an arc - character sits bottom left but in animation cell 0 of jump
Play sound - no sound.
Sound would be tied to the counting of position I would imagine.
This is the first event where a vertical change in position is required.
Graphics hardware seems ok though, if the running event is absolutely fine then i'd say the sprite positioning and animation is fine.
So, I think this is more code execution than hardware personally.
The game will be keeping track of a counter to work through the animation cells and the position and tell the screen to scroll etc - that's the bit that's not happening.
Verify the roms and then if they're ok, check the continuity between the sockets and their associated items (laborious job but worthwhile to find it) OR...
If they're those original really crap sockets then probably pull and replace them to start with.
This could also very well be a failing RAM or RAM access logic - ie., the position counters are at location N and that location and above it is starting to fail.
