Joust 2 locking up after rug pattern
mecha
10CR
I got a heavily battery damaged Joust 2 in. after cleaning up the mess and replacing all the headers (they had goo underneath them or the solder was rotten from the outgassing) it would often not boot to the rug pattern at all. it would sit on the grey line pattern, which is what the video board outputs with no CPU activity. after a lot of experimenting I eventually deduced that the roms 3 and 4 on the CPU board (program roms?) were crashing the game, I was able to mostly get it to come up with the rug pattern on power up.
the next step was figuring out why roms 3 and 4 were crashing the game. I found that the chip select pins on both roms were not pulsing like rom 2 was, for whatever reason those 2 roms get it from other places. I only had the Mystic Marathon schematics to work with, I just backtracked from the roms 3 and 4 and started basically replacing all those chips. I thus restored chip select to those roms.
I still suspected all along that something was wrong with the reset circuit due to the 3904/3906 transistors being in the immediate path of the leaked/outgassed batteries so I replaced all the 3904s since I have a lot of those on hand. I now have a rug pattern every time I power it on, but often when you mash the CPU reset button it still won't always catch properly. there are Q9 and Q10 parts on Joust 2's CPU that are not in the Mystic Marathon or Turkey Shoot schematics, and the battery fiasco wound up burning the numbers off the parts. I suspect they're 3904s from how they tested, but when I put new 3904s in and replaced the one 3906 with a 4403 (supposed to be compatible parts) it wound up hosing the reset again, so I put the original parts back in.
there are times I will manually reset it and it will just start drawing random garbage on the screen, or it will start animating the rug pattern draw backwards line by line with each reset. so this is why I think something is still screwy in the transistor network for the reset. there was also a resistor that broke the leg off, probably from exposure to the battery goop, but I was able to at least solder that back together for the time being.
ultimately where I'm stuck is it will complete the rug pattern cycle, but before it can progress to the video rom test screen it just locks up. it will either just stop moving, or you'll see that scrolling rainbow line thing.
I haven't done anything with this in 2 weeks, I was going to send it off to gamefixer to take another look at it, but due to the size of the box shipping won't be cheap. so if anyone miraculously knows something I'm overlooking, please help.
video: https://www.youtube.com/watch?v=HUYPyrGyz3s
colorful visual aids in attachments.
