Joust color issue
chubsta
547CR
Here i go again with a problem - i m really not luck with these things
monitor test pattern should show the following sequence
red, green, blue, white, black, yellow, cyan, magenta
instead i get
obviously the colors are messed up in the game too. the test sequence for colors should be the following:
light red screen, red screen, dark red screen
light green screen, green screen, dark green screen
light blue screen, blue screen
instead they are:
dark red screen, red screen, light red screen
dark green screen, green screen, light green screen
blue screen, light blue screen.
The manual states the following in relation to the color bar test (Test 7):
"if color ram test 6 indicates no faults, symptoms at left (color bars: double width, half width, transposed, missing) suggest a fault in 1A, 1B, 2B or 2C chips"
the only error i get with test 6 is that the sequence is opposite, the colors go lighter instead of darker in the sequence.
in test 7 i have missing colours - no white, yellow, cyan or magenta. Also, the black is in position 4 and 8 instead of just 5.
hope this makes sense!
anyone got any ideas?
tb lilley
5 Star
1,686CR
Yes, makes sense. What the manual is telling you, I think, is that you've got a colour RAM problem with the chips at either 1A, 1B, 2B, or 2C. It's either the chips at those locations themselves, or the transistors located very close to them at Q1, Q2, Q3.
If you look at the Drawing Set you'll be able to spot where the chips and transistors are. Locations are also marked on the board itself.
If I were you I'd pull and test the transistors first, because that's the easiest job to do. If you find a duff one then replace it. Other than that, it's a visual inspection of all 7 parts - just look for the obvious stuff: dry joints, broken traces.
If all else fails you could just shotgun the 4 chips. Or send off for what should hopefully be a quick and cheap repair.
bomjac
453CR
Cab had been at John Higgins place for about a year. Somewhere along the line it had stopped working, John had already replaced some transistors to no avail - only other thing in the line was the decoder proms if I remember. Did some swapping around between the 2 CPU boards and managed to get a working set. Also managed to get the prom the wrong way round in the spare set - oops
tb lilley
5 Star
1,686CR
chubsta said:
You lot make it sound so simple...
Ha ha!
It's not too complicated really.
Your def missing yellow, and magenta. Yellow is produced by combining green and blue. Magenta is produced combining red and blue. Common denominator there is blue - so whichever RAM colour chip (1B, 2B, 2C) that is responsible for blue is likley to be the culprit (I don't know which). But as the board has no problem displaying blue on its own, it may also be 1A.
Simples. Sort of. But to be honest I'm making most of this up and could easily be wrong. But that's where I'd be looking (but my record of board repair is pretty ropey ...).
chubsta
547CR
im afraid my skills are limited to checking the voltages where the connector joins the main board and thats about it - they at least are fine.
i guess sending off for repair is looking like the only option...
anj
313CR
what douse it do when running a game , and what happens on a different game . i have seen stuff go faulty on test mode but play ok
chubsta
547CR
there are colors missing from the game, as below:
havent got a different game i can really check with at the moment.
I think i will put this one on the 'back-burner' for a little while as today i need to sort a Gorf and MVS cab out - the joys of collecting!
DanP
Administrator
2,232CR
If you're lucky it will be just one of the three transistors. I've seen this sort of thing when one of them goes. They only cost pennys and are easy to swap out so I'd start with those first if I were you.
Dan
VectorGlow
34 (100%)
900CR
Looks like a board fault to me. The colour circuit isn't overly complicated - could even be a failed colour RAM.
I've recently been sent a few Williams boards for repair and coincidentally one of them is Joust (it doesn't have a colour problem though).
chubsta
547CR
OK, time to start on this...
i have no real repair knowledge or background but am keen to learn.
i would appreciate it if someone could take the time to explain exactly what sequence i should do, bearing in mind the only tools i have are a soldering iron and multi-meter! For instance, how do i test a transistor?
Earlier today i changed all the caps on the power board and that now works fine so am not a complete and utter novice, but as i will be working on the main board i would like to be as safe and knowledgable as possible before starting out!
cheers for any and all advice...
chubsta
547CR
Replaced a couple of chips - 1A and 2B and some transistors as mentioned above and the missing colors are still missing but now the screen is totally over-saturated with red
i guess i am not good at this sort of stuff....
2 options, either send it off to get fixed by someone who knows what they are doing, or try to sell the cab on for far less than i bought it for...
either way the choice will be expensive....
4,058CR
Dude, DONT sell the cab on. DONT spend lots of money getting the boards repaired or replaced. This is a simple fault and there are people on here that can help you for not too much in the way of costs.
I'm not getting back into commercial board repairs, and have just got out of (a foreign) hospital so need a bit of time before taking anything on, BUT, I would rather help people out in this situation than see them throw a tonne of money unnecessarily at costly repairs, or just give up on something.
Providing you can be a little patient then we collectively should be able to get you going...
[EDIT] If you're willing to wait for me to get back on my feet, and you promise not to inundate me with questions by PM then you will be able to send me just the single PCB and I'll sort it for postage and a beer.
guddler2013-10-18 13:43:03
chubsta
547CR
than ks for the reassuring reply
i think the over saturation of the red is because i screwed the middle transistor up (Q2 - which accordiong to the manual is the red transistor - too much of a coincidence for it to not be the problem there i think.) and lifted the pad - i have tried to repair this but it is not making any difference.
I have read the logic probe thread but am not in a position to work on the boards outside of the cab whilst it is running so cannot do that without a big risk of shorting something else out so am holding fire on all that.
I desoldered and replaced the chips at 1A and 2B without too many issues, so at least i managed that but it hasnt helped the initial issue anyway, although if the red issue is down to the transistor then at least i havent bodged up the chip replacement!
chubsta
547CR
ok, spurred on by guddler's kind words and a bit of logival thinking i have made some progress...
as i said, i replaced the 3 colour transistors, and chips 1A and 2C. the origional problem of missing colours was not solved and i ended up with an extra one of the screen being over-saturated with red.
this pointed me to the Q2 transistor, which is in the red circuit. This was one where i had issues with a pad lifting due to inexperience. I thought i had fixed it but there you go.
anyway, i remembered that a multi-meter can also measure circuits so tested the Q2 tracks to their next points and found an issue with the leg where the pad had lifted - what i had missed initially is that it goes in 2 directions, i had only noticed one previously.
I have jumpered a wire to the point which didnt register as a circuit and the over-saturation has gone.
Now that's progress!! I may have caused the fault in the first place but at least i have been able to fix it, which i consider an achievement.
So, where to go from here - the manual states missing colors is down to a fault with chips 1A, 1B, 2B or 2C. I have replaced 1A and 2B so i reckon the next step is 1B - anyone agree?
chubsta2013-10-18 19:44:31
trm
2,877CR
I think 2C is a plausible candidate for the reasons outline towards the end of the Logic Probe thread. You appear to have full colour control of the primary colours so it can't be 1A (plus you've proven that by the sub) and 1B/2B are key to generating the colour demands and you can get full R/G/B so they're clearly able to output all of their data pins. The Data Bus would give more significant problems if it was faulty I suspect, so that leaves the address inputs to the 1B/2B RAMs therefore 2C being faulty, or 2C is getting dodgy input but that's being fed from the address bus which like the data bus, I'd expect to see much greater faults if that had issues.
I'm not sure how a Joust set is physically arranged but don't you have any way of probing the 16 pins on 2C as a test? I think you'll find a dead line there.
cheers
chubsta
547CR
just replaced 1B and still no better - still has the colours missing - only one chip to go, which is 2C so lets hope you are right on that one, and then i am out of ideas!
chubsta2013-10-18 20:48:00
