Joystick mounting plate
WTGBoab
23CR
Afternoon,
I ordered a new set of joysticks for my cab I bought from Vic.
Only thing is the plate is too small to fit in the mounts, well I can get 2 screwed in and it's playable but I would like it to sit flush and not move around.
I tried calling a store and the gent was very helpful and he was mesuring the stick I have and said that sadly none of the mounts they carry would fit
Does anyone have any idea on where I can get a mouting plate for the Supreme Video cab?
Thanks in advace.
Rob
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
what size mounts do you need
tell me the hole spacing as I have 2 mounts here NOS that I removed from a joystick to swap out the mounts
EDIT: I think you need hole spacing 66mm x 76mm
show me your joystick and iw ill tell you the compatible plate as I had the same issue and managed to get the right mount silverfox07862014-05-01 14:30:13
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
Check your hole spacing on your cab
If I am right and your hole spacing is 66mm x 76mm then those joysticks wont fit
I have compatible joysticks here that I can sell you if need be
but that's only if they are 66mm x 76mm hole pacing that you need
WTGBoab
23CR
Yeah you're right the spacing holes are 66mm x 76mm.
Can I get a plate to replace the mounting plate that is already on them or do I need to purchase new joysticks?
ZedEx48K
8-Bit
1,423CR
silverfox0786 said:
your right it don't need to be pretty but it need to be aligned correctly or it will be off centre from the hole
I you can't use a ruler and pencil you sure as s**t are gonna struggle to do up your zipper never mind fix up a cab!
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
yep your right there but that's not what I meant
the point I was making was drilling the holes to match the joystick holes and then that to match the mount holes where we know the mount holes are 76mm x 66mm the joystick holes are gonna be ruler measurement guess work and even 1mm off an it will be misaligned
trust me it happens to the best of us where a hole drilled gets misaligned for what ever reason
yeah 1mm-2mm is negligible but pretty annoying for the owner to see and know its misaligned
