Joystick
bobbinshorse
0CR
[uk-vac] Joystick
Hi there,
I am new to this group, having joined as I am starting to build a
cocktail cabinet for MAME.
So of course I have a question....... :)
I've decided I'd like to try the Ultimarc T-stik Plus joysticks, which
are switchable between 4 and 8 way from the top side.
I'm not yet familiar with all the UK supliers, and a Google brings me
US suppliers only - can anyone tell me if there is a UK supplier for
these? If not, I guess I'll have to bring them in from the US.
Thanks,
Roger Thornton.
4,058CR
Re: [uk-vac] Joystick
Welcome!
Ultimarc IS a UK supplier. Actually, a UK and US supplier I believe.
Martin.
On 20/2/06 12:21, "Roger Thornton" <look@thathorse.wanadoo.co.uk> wrote:
> Hi there,
> Thanks,
> Roger Thornton.
bobbinshorse
0CR
[uk-vac] Re: Joystick
Thanks Andrew & Martin,
Nice that people I know are here, I feel so at home already.... :)
Is there a seperate website for Ultimarc as a UK supplier? The link
from Andrew ships to the UK, but from the US. Is that how they
work, or do they hold stock over here too?
Tried the simple changing .com to .co.uk, but that doesn't bring
anything up).
Roger.
A
andrewhannay
Guest
RE: [uk-vac] Re: Joystick
I just assumed they shipped from the UK, didn't realise they might be in the
States.
BTW the Mag stick I mentioned is a magnetically centered 4-8 switchable
stick.
The J-stik or even the E-stik is the normal 4-8 switchable one.
Got a bit confused.
Andrew
smf
15CR
Re: [uk-vac] Re: Joystick
> anything up).
I don't know where they ship from, but AFAIK andy is in the uk.
You could always try phoning him
http://www.ultimarc.com/contact.html
>From the USA: 01144 208 5429404
Rest of world: +44 208 542 9404
UK: 020 8542 9404
Isn't it nice of him to tell Americans how to dial internation numbers.
Phill
bobbinshorse
0CR
Yep, as far as I can see it's the same as the T-stik but with the
magnetic centre instead of the spring.
Phill, you're right - in the UK. I didn't look at the contact page,
I went part-way through the order placement instead and noted
shipping prices quoted in dollars, even though I had selected prices
for goods in UK pounds. So I assumed a US site. And I was wrong.
Thanks for the assistance.
Roger.
smf
15CR
erikthecat
21CR
Welcome to the dark side of video games Roger.
had enough of the pinball?
where are you finding the time for this project? :)
i've had several sticks from ULTIMARC all very good.
the puckman style one has quite short throws,
are a little 'clicky' (Mmmmmm micro switches),
very good in 4 way mode, but slightly strange in 8,
but you will get used to it in time,
but i understand these things are just all in the nature of this beast
and all IMHO:)
Regards,
GaRy:)
The Machine: Bride of Pin*bot (TM:BOP),Williams (c) 1990.
www.SplatThatCat.com
Build yourself a retro style arcade cabinet...
play classic games, on M.A.M.E.
GAME NOT OVER!
other stuff
http://uk.pg.photos.yahoo.com/ph/erikthecat@btinternet.com/my_photos
bobbinshorse
0CR
Hi GaRy - time and space will both be problems when I start it; it's
planning and material aquisition just now. Pinball has ground to a
halt temporarily until I move house, the garage is stacked to the
ceiling, (which is 10' high), with them..... :) But there's JUST
room in front of them to build a nice little cocktail cab. I hope...
I noticed the joystick was short throw and a bit clicky, but I've
read all sorts of reviews and info and decided it was the best
solution. I won't be able to get at the underside of all the
controls very easily, without disassembling control panels, so a top-
side switchable from 4 to 8 way is more or less essential. And the
Omni-Stik Prodigy looks like it needs a wooden control panel if it's
going to be mounted neatly, but I fancy a metal panel, so the
Ultimarc looked best. Although sourcing metal panels is now proving
tricky - where are they? (I emailed Gremlin Solutions last week,
waiting for a reply from them).
BTW, the stuff from Bay Area should be here soon, (I hope). It was
sent about 2 weeks ago, after they had to wait for some stock.
Regards,
Roger.
