JPM Gamebox Touchscreen Calibration
PMiddy001
7CR
Hi all,
I've noticed that my touchscreen isn't aligned to where I'm pressing. Does anybody know how to recalibrate the screen on one of these JPM Gamebox machines?
I thought that maybe turning the refill key would bring up a menu that would list this option but, you guessed it - it's just for refilling!
Any help in easy step by step instructions would be hugely appreciated.
Best Regards,
Pete
pubjoe
875CR
Just coming in with a total guess but did you open the doors before turning the refill key? From memory that's how you'd get into the setup of old AWPs etc.
PMiddy001
7CR
No, the door was closed. Thanks for that, PubJoe.
It's good to know that the refill key could be the way to access the menu after all. I'll crack the door open for my second attempt.
PMiddy001
7CR
Thanks again, PubJoe. I opened the doors and turned the key, sadly this brought up the same menu - but with the top door open (the one that goes around the screen) I noticed a black switch. Clicking this brought up the menu that I needed.
I had this machine advertised last week on eBay and at the time I believed that the top part of the screen was inoperative as the lifelines on Millionaire were unable to be selected (after winning them through the fastest finger first round) - this comment in the condition description must have put people off. I'm glad it did now that it's all working as it should.
Thanks again,
Pete
PMiddy001
7CR
Does anybody know how I could speed up (or even avoid altogether) the verifying games screen on boot up? It takes about 15 minutes. Surely this only has to be done the once unless there's been an upgrade.
Again, any help would be appreciated!
PMiddy001
7CR
Thanks for that, PubJoe - at the moment my Amstrad 464 loads quicker!
As you're mentioning fruit machine forums, as it happens I've just joined MPU Mecca (for problems with various fruit machines). I just didn't think that it was a fruit machine question. I've heard that certain forums can get annoyed if you put something in the wrong place!
Thanks again. I'll test the water with those guys - that Fruit-Emu is subscription based, so I'll try to avoid those for as long as I can!
pubjoe
875CR
Ah, MPU Mecca's probably good. I've hardly used the sites. I think the Fruit-Emu subscription is new and it's for access to downloads. I saw it mentioned in a banner when checking if those places are still active.
PMiddy001
7CR
I think the price plans appeared when I tried to join. I don't think they gave me an option to join without some kind of subscription fee, the little tyrants! I haven't tried DesertIslandFruits but will certainly give them a look!
gunblade
9,110CR
bloody old hardware in those, you could try replacing the cdrom drive and maybe up the ram
i used to work on this stuff when it first came out, they were slow loading then but not 15mins
PMiddy001
7CR
Thanks for that, Gunblade.
I'd say that the PC boots up very quickly, I'm guessing a shortcut to the Gamebox software will be in the autostart folder and it's when that software takes over that things slow down.
I was looking for maybe a menu that gives the option of skipping the verification process somewhere in the software itself. I know it's not mentioned in the software menu that I accessed the other day when calibrating the screen, etc.
I'm also guessing that it won't be found in the BIOS settings as that's obviously for the PC starting up and not the clunky software that's loaded afterwards.
