JPM Gamebox
dsxof
2CR
Seemed like a good idea at the time as it was virtually free but there seems to be one major ingredient missing which is the games DVD and also the screen don't work.
Any pointers appreciated for monitor not working and anyone know of a DVD replacement?
Will have a quick poke about but I think a trip to the tip is on the cards for the weekend.
dsxof2013-09-04 19:32:47
andrew96
Unfixable? What's that word mean?
899CR
I seem to remember when I had one you have to have the right games on the disc or they just won't work. I did try and make one up with more games on and it just wont work! the games have to match the dongle on the port on the pc, its like a old style printer plug with a silver disc in it. If you don't have that then no hope its a scrapper!
andrew96
899CR
I do have discs for I believe to be a gamebox 4 and 6, they was marked '160' and the other 'CD0260' but they each had different dongles, There useless without the right dongle, no no point unless you know more about the gamebox. I hated them so sold one and scrapped the other, horid things!
ZedEx48K
8-Bit
1,424CR
Format the PC inside, install XP then go get the Paragon, itbox and GW games with the other needed files and you will have a sh*t load of free to play quiz games :)
dsxof
2CR
The dongle appears to be there, or there is a 9 pin plug plugged in the dongle slot. If you could spare the discs for me to try I would appreciate it.
andrew96
899CR
you could do that but it is not worth the bother, the pc is ssslllooowwwwwwww and the motherboard will be suffering from poor capacitors so will definitely need changing! by the time you have done all that you might as well skip it! the whole machine is soo big and outdated!! you could put a pc in but then you need a serial port for the touchscreen, is it really worth all that effort for something that's worth in perfect working order about £100 and not working around the £0 mark (also the touchscreen over the monitor is very bad, again not worth it.
dsxof
2CR
Thanks, will bear it in mind.
andrew96
899CR
dongle is 25 pin plugged into the printer port. If the disc aint there the chances are high nor will the dongle!! that's already been sold off as that's the bit people want
dsxof
2CR
Ah I was thinking of the data pack, dongle goes in the 25 way purple slot then??
andrew96
899CR
most likely the chain of events.......
the gamebox would keep resetting or alarming, eventually the capacitors on the mother board got so bad the processor either blew because they could not smooth the processor supply, or the processor fan seized up so processor overheated and went, so the pc would no longer boot, so the disc and dongle removed to sell, the rest is scrap, that's what usually happens with them
TonyElyod
266CR
I have a fully working one..
I,ll check if mine has a dongle..I cant remember TBH
I do know they weigh a fookin TON...Literally !!!
andrew96
899CR
yes it does, without it the premium games like weakest link or who wants to be a millionaire just won't work. I cannot remember it all now as I didn't have one for long and it was over a year ago now, so some games might work without it, but I do remember it runs off hard drive but does have to access the disc, so without a disc it won't boot far!
mathj
499CR
I can second andrew96 on this one
there used to be a who wants a to be a millionaire one of them where I used to work
the isa card kept failing on that one and I had to keep stripping it down to reseat the isa card and I remember that dongle plugged in the bottom
and the machine was a right pita!
can you replace the pc and make a touchscreen digital jukebox/mp3 player out of it or something usefull?
the touchscreen is just a sheet of plastic stuck to the crt screen iirc so any 14" monitor can be fitted to it in theory with a small bit of surgery to the loom
math
TonyElyod
266CR
I'll have a deco in the morning.
I have approx 20 machines in the garage & I literally cant get to any of them without moving my twin driver out onto the drive
