JPM Gamebox
simonden
20 (100%)
1,042CR
I have a DVD and matching dongle going spare (and a few other spare parts from these machines.)
Although TBH, unless you want the coin functionality to work, you may be best doing something similar to what I have done, which is basically:
Remove all internals except the monitor, touchscreen and speakers (the speakers are crap and not used but are needed to remain to shield the monitor from going Purple, remove the sound amp as it is perfect partner for a JPAC in a MAME machine).
Put in a new PC, a P3 will be fine, I use a P3. The already installed PC may be fine, but I screwed the BIOS and can't boot that one now.
Install Windows XP and touchscreen driver (i have the driver but it is just a download from manufacturors website, just can't remember which one until I get home).
Install Simpletouch FE and SWP ROMs (I have all of these if needed)
Install your favourite touchscreen jukebox.
Install loads of PopCap games (as these work fine with SimpleTouch FE)
EDIT: Put in some powered PC speakers (loads of room when coin box removed, there are grill holes at the back on the bottom)
Away you go
simonden2013-09-05 09:21:20
simonden
20 (100%)
1,042CR
dsxof said:
What do you want for the DVD and dongle mate?
or postage costs and a donation to the forum.
Let me dig them out as they are in 2 seperate places.
simonden
20 (100%)
1,042CR
andrew96 said:
Will look into your other option as well, thanks.
the pc DOES boot doesn't it?? if it don't the dongle and disk is of no use whatsoever
That is a good point as you can't use the DVD/Dongle on any PC, the gamebox PC has a modified BIOS and a customised win95 image.
I really do reccommend the other route, it is cheap, easy and turns your gamebox into so much more than just an SWP.
dsxof
2CR
Yes PC does boot but keeps beeping which I assume is alarm to say no dongle or disc?
I'll try dongle and disc first if you don't mind to get the thing running then I'll look at upgrading as you recommend later on once I assemble another PC etc.
Let me know postage costs and I'll do forum donation later tonight (will shift some funds into payapl),
Thanks for your help.
simonden
20 (100%)
1,042CR
That is OK - you can do postage / donation after you have received it as I know where the dongle is, but disk could be in 1 of many different places, so may take me a few days to find.
simonden
20 (100%)
1,042CR
Was in the first place I looked, you can guarantee that if it was something I needed, I would still be looking for it at christmas!
There appears to be a battery in one side, but not in the other side, can anyone confirm if this is normal? (I have never used it, i converted the gamebox as soon as I got it). Also if it is a battery, i guess the one still in there will need replacing.
andrew96
Unfixable? What's that word mean?
899CR
yep normal, there is a place for another security chip for adding in newer games if needs be, but it just has the one normally, a future upgrade that was never used perhaps??
bleeping pc....... well it should boot, come up with a bios screen etc but if it is just bleeping and no screen then it is likely the motherboard as I described in a earlier post
3CR
if you stll have your gamebox i have the pc with dongle and gamebox 6 just sitting there doing nothing if you want it. all working just dont need it
