just got a whack!
8,292CR
I was adjusting the red driver on my monitor chassis
and got a mighty whack!.
chassis is 115v
my question is is there 115v flowing all around the chassis components ?
tb2000
3,584CR
Depends on what you touched and what the chassis is. The pot adjusters have hardly anything running through them, but on a Hanty Polo for example, the main colour transistors have near 200v running through them. Also, remember there's a fair amount running through the G2 cable coming from the lopt as well (that's the one that solders into the neckboard), low current but still somewhere near the 400v mark.
J69
281CR
Been there, done that
Shouted f**k! in front of my Father in Law
obcd
3,830CR
You didn't mention what chassis? Some of the older ones need an isolation transformer and would indeed have 110V all over the chassis if you don't have one.
For the rest, I can only confirm what was told already about the neck board. Focus pin voltage is pretty high as well and also nearby.
8,292CR
Chassis is a Sanwa pm1745 .
I screamed and was glad that it stopped. When it did
Yeh quite a thump....
Pretty lively
I think I might have high voltage leakage,
I get some slight crackling noises... Shortly After start up..for around 25 seconds
Also bad pincushion curves
Gun blade I sent you a message over on AO...repair request..
