JVS Oddness - sorted :)
chunksin
21 (100%)
733CR
Got a strange issue on my JVS IO, I think it might be faulty but wondered if anyone can offer any advice. The IO is in an Initial D 2 cabinet and it isn't registering the start, view change or credit button. I've traced the wires through the various connectors and tested continuity back to the board and it all seems fine. Also tested the buttons themselves and they are working OK too.
The JVS input test shows the analog inputs are working fine, steering and pedals look good. The shifter registers buttons in the player 2 line but I get nothing from the VR panel in the player 1 line of inputs. Robotech very kindly sent me photos of his JVS test for comparison - one odd thing is that the second input from the right on the player 1 line is always on, this is the same on mine and robotechs so I presume its normal on an ID cab.
Can I test the inputs by unplugging the 60 pin digital connector and making contact between the input pin and ground? I know I have to join pin 1 and 3 to get inputs to register at all.
Thanks,
Rich
Chunksin2017-02-05 16:01:07
terminator2k2
327CR
Hi Rich...i take it, its the sega type 1 i/o?
you can just short the pins out, as that is all the switch is doing.....
do you have a naomi in there now? you could disconnect the 60 pin connector and connect pins 1-3 and test the inputs....
chunksin
21 (100%)
733CR
Thanks Chris, all sorted, tested the whole P1 row of pins no issues, checked the pinout on the 60 pin and checked the wires behind the panel, they were wired up wrong! P1 start and Output 4 were switched together
