K4915 vertical collapse
Lurch666
21 (100%)
4,519CR
So I got the pedals working on this championship sprint...
http://www.ukvac.com/forum/atari-championship-sprint-repair-help-wanted_topic389546.html
But the monitor had a yellow tinge and the picture wasn't right.
Adjusting some of the pots on the monitor helped but then we got vertical collapse. It was while adjusting the vertical size so I'm assuming the pot might have bad solder joints or it's failed.
I have the monitor at mine now and am looking to remove the PCB but the neckboard has some sort of white glue on it:
Am I ok just pulling this glue off or might I cause damage doing that.
Monitors are not my strong point so want to proceed with caution.
The monitor has been discharged.
jengineer
49 (100%)
1,205CR
Hi mate, yeah that's just some sealant from the factory, to stop the neckboard moving, just gently wiggle it off
monitor needs a good dusting off too
Lurch666
21 (100%)
4,519CR
Ended up using tweezers to start it and managed to peel it off ok (I think-no obvious damage).
If there is a next time I'll use my scalpel first.
Managed to remove the V.size pot and checked it out of circuit with my multimeter and it was all over the place.
A spray of deoxit and it's as good as new.
Replaced it and now just need to wire the monitor up to my old hantrex PSU and see if it's made any difference.
Lurch666
21 (100%)
4,519CR
Finally got a chance to fire this up and it appears to be OK now.
Couldn't check with a video signal but there appeared to be vertical deflection again so it was probably a bad joint/oxidization on the pot.
Sprayed deoxit on the rest of the pots.
Will have to wait for a chance to return the monitor to it's cab to fully test.
