K7000 Zenith Chassis
PhilT
154CR
I have a K7000 monitor with a Zenith flyback on it. Its not working, just blows fuse F1 after a couple of seconds. Its been sat in someones garage for god knows how many years but the tube has no burn so I did some investigation.
The regulator diodes just after the fuse were cracked so I replaced them, HOT was shorted so I replaced that too but it still does the same thing and I think it blew the HOT again but I haven't pulled it back out to check yet. Got a bit of a whistling sound too. Also checked D18 and C36 (I think - cant see markings) which tests fine.
Worrying is the fact that it looks like its had some work done in the past, most of the caps are 105C so I expect they have been replaced already. I just wonder if it was shelved because they couldn't fix it originally.
Anyway I was wondering what the likelihood of this flyback being bad is, I dont want to dump a load more in parts and time into it if its going to be the flyback and its an issue that cannot be resolved anyway because I cant buy one. I read varying accounts, some say its more reliable than the standard K7000 flyback.
Or should I send it off to an expert to pronounce on it!
campbell87
56CR
Hi Phil,
Im no pro or anything, but I've seen some videos on you tube and its a good idea to check for any cold solder joints on the chassis.
Ace`
PlanB contributor #1
40 (100%)
4,040CR
I've had 20" and 25" K7000 zeniths and just decided to pick up a replacement standard WG chassis and use the zenith ones for parts. I don't see the point in putting time and new parts into a chassis where a replacement flyback isn't available. Also those zenith flybacks are just as unreliable as the non zeniths from what I've seen.
PhilT
154CR
thanks Ace, think you confirmed what I sort of knew all along. I will try and track down another chassis.
Thanks.
