Kicker machine resettable fuse update
bones
1,628CR
So the 1st post won't allow me to upload another post to it so a small update
I've managed to order some replacements,due at end of week.
I got the machine working again by adding a heatsink to said fuse and positioning a small 4 inch fan above it. A datasheet on these particular fuses does say that they will do 7000 crystalline breakdowns in its lifespan.
I suppose I'll have to see if the replacements will operate without the heatsink/fan. It seems there are design issues present also in regards to the start switch being pressed after the ball arm is released. It will power the solenoid 2 times twice before finding its way again and this can go in indefinitely until the ball returns to its start position. Very bad in terms of unnecessary solenoid activations which you wouldn't even know about as it doesn't make a sound when the balls in the play position. It looks like design wise this fuse breakdowns each and every time the button is pushed knocking 1 of off its projected operational lifespan. Hmmm I'll have to see but defo looking like a suicide battery approach at the mo lol.
bones
1,628CR
Just to finish this post off for any future reference. The new resettable fuses arrived so a new one has been installed and the heatsink and fan removed. The kicker has now been working fine for almost 2 weeks.
Lesson learnt here is that yes this fuse does break down on every play as by design. I guess after 7000 uses it's going to be hit and miss until it finally malfunctions to the degree where it needs a minute or so to cool down. Normally I suppose you'd get stung for a minimum of £120+vat & postage for a replacement PSU board. So in conclusion, yes it could be deemed as protection for the solenoid but it is designed so as it does have a finite lifespan.
