Klingon Board constantly adding credits
cmh
3CR
Hi Everyone,
I am very new to this, with little experience so I am hoping someone can help me :)
I have a Namco Point Blank 1 cabinet, the trouble is that when I power it up, it is constantly adding credits (causing a constant annoying sound), even when you are playing.
I think it may be something to do with the Klingon v1.1 board. All the pins are set to allow free play.
The guy who sold it to me says it worked fine, so maybe something has been dislodged inside.
If there are any pointers/guidance that would be most welcome!
Thanks all,
cmh
3CR
Hi Dave, seriously I appreciate the fast reply - thank you!
I am not sure which wire it is, I am googling for it now though
cmh
3CR
Interesting, I see that the device does not recognise coins passing through it anyway (I set the 5 binary switches, to move it out of free play mode, but it does not increase the credits when I put coins through)
Flinnster
The Dino King
29 (100%)
2,566CR
Constantly crediting could be as simple as the connector have been connected on the wrong pins, so shorting something to ground. But would need photos of how things are there
  • Like
Reactions: cmh
cmh
3CR
Hi Big10p
Yes, I took the photo when in the middle of adjusting the DIPs, I have them all set to the up position, to give freeplay. It's like the coin board is telling the machine that it is constantly adding credits (which maybe is normal, maybe the Klingon is not intelligent enough to know when to add credits, so it just adds them all the time) - maybe it is the machine itself, is not able to tell when "it's stomach is full" and then ignore the additional credits being added?
When I power the machine on, the screen says 0 credits, then it starts filling up within a few seconds and gets up to 9 credits - but instead of stopping it keeps beeping like credits are being added, but the number just stays at 9, which I guess is the max
big10p
Coins detected in pocket!
6,093CR
When you put a coin in, does it go into the coin box, or come out the reject slot? It may infact be a fault with the game PCB. Check all connections on the game board are good.big10p2019-01-21 19:34:44
cmh
3CR
Hi big10p
It comes out into the reject slot. I set the pins to a valid setting (to move it away from free play so it would accept coins), but the coins just pass through to the reject slot.
The guy who sold it to me said it worked fine and the guys who shipped it were not very gentle in moving it, so maybe something has worked loose.
There are loads of cropped wires out of the back of the Klingon v1.1, but most of them are cropped, there are actually on 3 wires that make it to the PCB. I blew across them and made sure none were touching each other - it is mega frustrating, so I really appreciate you responding :)
TheDaddy
14 (93%)
7,230CR
You need to disconnect the coin mech so you can isolate that as an issue , Then move to wiring , Then the PCB. If you disconnect the mech completely and its still coining up then move to the next step. A coin is added by a simple pulse forcing the pcb to see a low signal , Once it does it adds a credit. Its a very simple system , The mechs are not so easy sometimes.
Dave.
  • Like
Reactions: cmh
cmh
3CR
Hi TheDaddy,
I can't seem to find a wire that goes to the coin mech - seems to me that it is joined via a socket/pins - does that sound about right? Just a bit nervous to pull it off!
Sincerely,
cmh
3CR
Hi Supersprint - yes I do have a multimeter - although not that skilled in using it :)
If there is anything I can check, I can try
And thanks to everyone for helping, I will have to be posting out some beers
big10p
6,093CR
Er, just noticed in the pic there's no ribbon cable connecting the klingon board to the coin mech. Did you pull it off? Or does the klingon plug directly into the mech?big10p2019-01-21 20:05:19
TheDaddy
14 (93%)
7,230CR
cmh said:
Hi TheDaddy,
Sincerely,
If you are nervous you may be better getting someone in just to be on the safe side. You don't want to make things worse !
Dave.
SUPERSPRINT
1,035CR
Ok, so put it to continuity which is the beap sound and also this symbol
Switch the machine off and find the button on the top left of the Klingon pcb marked service.
When that button is pressed it adds a credit. I would check the most simple things 1st. Put your probes into the centre and right holes on the multimeter assuming you have 3, 2 red and 1 black.
Touch the ends of the probes together and you should hear a beap and a reading of 0.00 for example, or something low (ohms) like 0.1 or 0.01 etc.
Does that service switch click down and spring back up when you press it? If not then it maybe stuck. If it does then it may be shorted (internally stuck)
There are 4 terminals on that switch, easily accessible from the solder side of the pcb.
I would start by checking all 4 terminals, difficult to see what’s what from the pic, but what you want to check is that you have a beap/continuity when you press the button and that it is broken when you take your finger off it. Check between all 4 terminals, using all combinations (I can’t see what is the common/ground/switch line/ from the pic, so check it all. What you need to establish is that the beap is present when switched on and not present when released.
  • Like
Reactions: cmh
cmh
3CR
Hi big10p - I think it connects directly to the mech - I can see that it is connected directly without a ribbon.
@The Daddy - yes I am a bit nervous to pull it out!
@ Supersprint - I will get the multimeter from my father in law and give it a try tomorrow evening (bit late for me to go round there now)
Thanks again everyone! I will report back my results
