I made a spreadsheet with the JAMMA Pinout reversed:
The power connections go to the player buttons on the whole. They probably wouldn't be expecting voltages though.
When you reversed it did it exactly connect in reverse or do you think some of the pins may have been 'straddled'?
I take it there is no 'Key' to your connector?
When I have had a Keyless connector I mark where the Key should be by drawing a line on both sides of the connector in permanent marker. It's so easy to reverse them otherwise.
funhouse2019-06-01 12:32:51
