Kung Fu Master
paulcan69
943CR
Ok this is odd, I would kindly like your input on this please folks.
I know mame and real pcb roms can differ but normally I see a pattern and can work out a plan
I have a Kung Fu Master IREM orig, with "KUNG FU MASTER" on the title screen
So playing it the other night for an hour or two, stopped playing and sat there looking at my phone, looked up and screen has random letters everywhere and messed up backgrounds
I pulled the roms and labelled them as the stickers and downloaded the main (only) KUNG FU MASTER irem orig roms from mame (I think)
Anyway this is my romcmp results:
Where do I go from here?
They are those sh*tty Mitsubishi M5L2764K roms that seem to lose data for fun, but I was thinking all 100% and one or two slightly less at 98% etc...
Hmmmm have I got the right romset?
Too many are too far away from 100%
I can understand most being 99% etc... over time loosing a bit...but this much?
Bare in mind it was playing 100% for weeks before this and upto the moment it shat itself?
Off to try the Spartan X roms and report back!!
paulcan69
943CR
Ok tried in mame and it doesn't do anything when you press test
So I guess kung fu master doesn't have a rom check?
Off to try dip switches next
back in a mo
paulcan69
943CR
Well tried the rom test in test mode and it stays scrambled static
If you put Kung fu into test mode you get a scrambled screen just before a black screen with
Rom1 ok
Rom2 ok
Mine doesn't get that far just stays on the static screen so CPU or try roms next?
Thanks in advancepaulcan692013-06-25 19:19:03
Ace`
PlanB contributor #1
40 (100%)
4,029CR
If it was me I'd blank all the eproms or replace them and use the known good rom images in mame. If you still have problems and it turns out your roms were good just not in mame you still have a backup copy of them on your PC.
cmonkey
1,659CR
It's unlikely to be the CPU as, if that were faulty, I doubt it'd even get as far as the static screen. My guess is that one or more of the eproms has failed. I'd go along with Ace and say burn a new set of eproms from the mame kungfum set.
