L2M2 Help
mjc022
1CR
Hi everyone. I've been working my way through an L2M2 conversion on a virtua racing wheel using silverfox0786's L2M2 board. Everything went smoothly until I hooked up the FFB motor.
I've triple checked voltage on RV1 and RV5 @ 20V and RV2 and RV3 @ 12.5v. The board recognizes CW and CCW, and I'm using the transformer from and Sega Touring Car Championship cab to power the motor.
I've tried two different logitech driving force boards hoping that was the issue.
I've got a video showing what happens when the FFB motor is hooked up. I'm hoping someone can point me to how I can start troubleshooting the issue.
https://www.youtube.com/embed/36P58L5wFrM
mjc022
1CR
Thank you. I haven't tried with a game yet. Didn't want to leave it hooked up too long just in case I would damage the motor or a pcb. I'll give it a try today and report back.
panpar227
114CR
Are the FFB motors in a Virtua Racing cab compatible? I thought the l2m2 was only compatible with the Daytona FFB motor?
Or are they the same motor?
mjc022
1CR
I did pick up the wheel from ebay and the description says it was pulled working, but
I don't have anyway to verify it outside of the l2m2 setup. Keeping my fingers crossed it works in game.
mjc022
1CR
I'm gutting a Sega Touring Car Championship cab, and although it was a model two, it used an incompatible motor for the wheel. I picked up the virtual racing motor on ebay based on the description it was pulled from a working cab.
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
im new to this as well i haven't even stated to assemble mine
but can i ask , that black and red wire
is that POWER?
if it is your in trouble and possible blow up every thing
edit~: i noticed you installed the optional clutch detect
did you enable it by solder jumping the underside
silverfox07862016-08-22 16:44:15
mjc022
1CR
Those open wires are from the potentiometer coming from the wheel and hooked up to the logitech board. The picks are from a short troubleshooting session and they've since be recapped.
mjc022
1CR
I had a chance to test the wheel in game on Daytona USA with the same results. I can say that when there is power going to the ffb motor I do feel tension when turning left and right, so that tells me the clutch is doing something, but the ffb motor sounds horrible when I turn left.
terminator2k2
327CR
have you adjusted ffb ini settings for the m2 emulator? as standard they arent that powerful.....
also check you have :
EnableFF=1
in the m2 emu ini file
heres mine:
terminator2k22016-08-22 17:15:52
mjc022
1CR
Thank you everyone for your help. I will go through the gameover thread to try to find any issues. silverfox0786, do you think maybe the signal on RV4 is where I should look?
terminator2k2, I have a second logitech wheel that I used to setup the m2 emu w/ffb settings on and adjusted them, and it works great. I will try making adjustments to the ffb settings with the l2m2 to see if it makes any difference. I would have hoped I would have gotten some ffb with my original settings.
Thanks again everyone. I'll have some time this evening to work on wheel setup again, and I'll post back my results.
terminator2k2
327CR
I think you may find the settings for the second logitech wheel will be a lot lower compared to the settings used with the l2m2.
mjc022
1CR
Hey everyone. Unfortunately I cannot get the wheel to give me the correct response. I've been over the gameover thread multiple times, and even ran into this thread on on arcade controls https://forum.arcadecontrols.com/index.php/topic,145767.msg1515821.html#msg1515821 which gave me the idea to test the motor and it is working 100%.
So I even went out and purchased another multimeter just to test my voltages and they were good. I'm very new to all of this, so I'm just kind of using trial and error to figure this out. Since the motor was working, I started testing the voltages coming out from CW N CCW and when I turned left I would get a roughly 31v on N and CW... when I turned right, I would 0v on N and CCW. So I tried switching E1 and E2, and was able to get the same results from it, just opposite from my previous test.
So I figured I may have messed something up when putting the board together and I found something. Before I get startd on a desoldering spree, I wanted to see if what I found would have any affect and possibly cause what is going on. It looks like I soldered U2 and U3 in the opposite direction. I'm keeping my fingers crossed that this could be the cause of my problems.
radfoo
48CR
It's a few years since I set mine up but I recall needing very different settings between games, I have 2 different INI files for Daytona and Sega rally even though they use the same emulator.
Have you run through the wheel tests in the Logitech app?
Have you set the pots per the instructions on the French forum? They give you a starting point but think I had to tweak mine to give a bit more force.
I used a model 2 wheel if that makes any difference.
Good luck.radfoo2016-08-24 08:19:02
mjc022
1CR
Thank you radfoo and terminator2k2.
I'll work on tweaking the settings as much as I can and see what I get. It looks like the motor and the board are good. I can't find any problems there.
