LCD backlight inverters help
system11
9 (100%)
345CR
Any ideas what this is or what the writing says? It's sat right in front of a large 80s monochrome LCD panel, the + and - are definitely some DC output, there's a 1000uf/16v cap across them soldered on at the back. The voltage only goes to the panel, the rest of the PCB it's mounted on has voltage supplies from the driving PCB.
system112016-10-24 17:27:19
system11
9 (100%)
345CR
I've mis-traced the wires - it takes DC input and outputs AC to the LCD!
Luckily I've managed to find a manual in an auction for a game that used the same panels, so in a few days I should have a scan!
system112016-10-18 17:31:26
system11
9 (100%)
345CR
So, I found that one of them works. It's making a lot of noise about it, but it works.
Without load it's taking 5v in and I'm reading 160v AC out. With the LCD panel connected I'm seeing 115v AC out.
Does anyone think that from the part number it should probably be 100v? Are any of 110/115/120v common LCD backlight power sources?
Sorry - this stuff is really new to me and I don't want to blow the panels up - irreplaceable.
obcd
3,830CR
I have seen such backlights that are a sort of flexible plasma's. It just looks like a piece of mica with 2 electrodes coming out of it. The voltage they operate on is not very critical. They simply give more light with a higher voltage. (Obvious within operating spec's)
andrewsm
485CR
Sure Ive also seen small mini fluorescent strip lights in LCDs too. That would also tie in with the voltage out. Volts would also drop once the tube is hooked up. They also take AC. Basically just an invertor?
