LED lighting - inside cabinet
david_orton_2000
Green Mario
344CR
Hey all,
I have a Gorf, however it has no lights or fittings.
I think originally it had 5 or so bulbs in there.
Has anyone put LED (strip lights?) in a cab?
-If so, any pictures or links to some etc. as would like to see what it looks like.
AFAIK, they just need 12V, so could tap this of the PSU, as probably only 300mA drain or so I'd expect.
Any help appreciated! :)
Cheers,
DaveO.
Flinnster
The Dino King
29 (100%)
2,566CR
Yep I was messing with that 12V cheap LED 'rope' lighting. It comes in a big spinny coil and you literally just connect 12v and ground and it lights up. For power drain, I could hear the sound amp on a game literally groan as I connected the entire reel
But if you are just using a few strips here and there, I'm sure you'll be fine. The entire reel was 5m or so, with LEDs every 4cm.
It was something like this: http://www.lightingever.co.uk/12v-led-strip-light-300-3528-5m-dw.html?gclid=EAIaIQobChMIzM_wj_qV1QIVZ7vtCh3QIgXiEAYYAyABEgLaLfD_BwE
I'd go for something with 'warm light'. The 'daylight' is so bright/blueish it's not a good replacement for old tubes / bulbs.
Flinnster2017-07-19 19:18:34
AnDyC
529CR
Dave, I had a strip of 12v ultra bright blue leds I stuck in my mame cab as I had no other use for them and my glass marquee is quite thick
Click
AnDyC2017-07-19 19:41:19
chadsarcade
Lord of Vectors (tm)
443CR
I've put LEDs in my Gorf. It looks fine, just use warm white as suggested. I had one of those rolls with the waterproof covering, I just cut a 12" or so length to replace each lamp.
RolyRetro
278CR
I bought a £10 LED strip light unit on Amazon that runs off a 12v source, used for lighting in caravans and motor homes. Added advantage of having a switch on it and just the right size for a marquee. Used this on my BAS cab tapping into the transformer directly.
ClickRolyRetro2017-07-22 06:09:29
5,415CR
Now prices are coming down and more are available it will be worth replacing old type tubes with them soon, good thing is the heat, won't damage the marquees etc with them in which is nice
big10p
Coins detected in pocket!
6,093CR
I prefer to use those housed 'caravan' strip lights, with a defuser lens fitted. You can get ones that take 240v, so you just connect it up to the existing marquee wiring. Beware of cheapo ones, though. I had one that only lasted about a week.
5,415CR
Thats the only problem, I bought cheap LED's for car interior lights, but there so naff they stop working, it's not the LED itself most the time, the other parts that drive them, in the case of these it's the resistors coming off the LED Leg, so probably quite a few just need resoldering
obcd
3,830CR
I prefer cool white for marquee backlighting as it makes the colors more vivid. Very old cabinets might have used ordinary lamps for backlight. In such cases, wharm white could give a more authentic look. If your marquee is very transparant, you might be able to see the individual led spots. Some replacement led fluorescent tubes have the led's covered so that no individual light points are visible.
david_orton_2000
Green Mario
344CR
Just want to say a big 'thanks', for all your replies - most helpful. :)
-This Gorf is a bit of a project, however the more things I can tick off the long list, the better.
In the end went with Flinnster's link, and already arrived, so will get stuck in on that this weekend! :)
All the best,
DaveO.
PhilT
154CR
I bought the same as Flinnster to sort the back lighting on my Outrun. The fluorescent fitting was damaged so I took it out and stuck a line of LED in there. The transformer that comes with the lights is built into the plug so I purchased one that has a separate mains wire and ran on voltages from 100-240 at the same time. Replaced the mains plug with the standard wiring loom connector and just plugged it into the fluorescent lights power supply which was 100v.
Just remember to wire up your LED the right way, or you may, like me, sit pondering for ages why its not working! (der its a diode!)
Good luck with the project, I have a Gorf coming when the next container from RGP arrives.
