big10p said:
Finding ones the right length can be a problem, though. The 'standard' sizes manufacturers do tend to be too long or too short.
I have that problem finding them over here, but easy to get in other countries, have given some ebay numbers below
robotech said:
I find them way too bright and distracting
At night time not as bad as the normal florecent tube though The ones i have anyway
I have that problem with the 'Cool White' which are very bright, although it can look really good in some cabs, if you ever go Four Quarters Peckham, look at the Asteroids marquee, it has the Cool White version of these LED bulbs.
The cool white looks good behind darker (mainly black) marquees, can make them stand out, with lighter colour marquees, then the warm white is needed otherwise it can be a bit overbearing.
Steve - ebay item numbers are:
Single:
https://www.ebay.co.uk/itm/322886288891
4 pack:
https://www.ebay.co.uk/itm/331504539371
Go for the 6w version as they are 450mm (for most arcade cabs) the 4w are only 300mm
They wire up as Live one end and Neutral the other, so just disconnect the input from the ballast, and the two bulb connectors and connect them to bypass ballast and starter.
