Leisure 2000
Ady
2CR
Hi all. Im new here. I have a leisure 2000 cabinet.it has a pc tower and has 32 classic games. It has problems starting. The pc seems to fire up but the monitor just occasionally flashes. If i plug a key board in and press f1 ( a fix the guy i bought it from told me about) the pc seems to make more noises and a voice sounds that says 'operational'. Nothing on the monitor though. Im going to try a different monitor on saturday but any ideas what else could be a problem please?
Fantazia2
2,246CR
Pressing F1 at boot sounds like the BIOS battery needs replacing on the motherboard, they are usually just a 2032 button cell, once you have a working monitor on there you will be able to see the error on the screen, usually for a PC it will be a warning about defaults loaded for a dead battery or time reset.
Not sure about the monitor, if its flashing sounds like the chassis needs repairing, although I would check the basics such as the power cable being secure and plugged all the way in.
Ady
2CR
Thanks for the reply. I have checked all leads are secure and they seem to be. Once i have ruled out the monitor i will check the bios. I really am not tech minded so any help is appreciated. When i took the monitor out i realised its rotated 90 degrees i think. How does the pc know how to format the games so the scroll in the right way, ie across or up for different types if you get what i mean?
Ady
2CR
Thanks dave. Im borrowing one on saturday so will try then.yeah i think the pc must be working as the 'operational' voice sounded.
Ady
2CR
Turns out it was the monitor. Managed to get a second hand one and by luck it was exactly the same size and dimensions so fits nicely. Frogger pacman and space invaders are go!
