Liquid Solder
paulcan69
945CR
Just want to start practicing removing surface mount customs with rework station and flux + liquid solder
(Gonna practice on scrap pcbs)
Can anyone please recommend a brand/type of liquid solder please?
Ace`
PlanB contributor #1
40 (100%)
4,035CR
I've replaced many customs with chip quik, even the best rework station you run the risk of damaging the part / pcb because of the heat required.
Also consider a large hoof / drag tip for your iron as it makes reflowing customs very easy and also pushes down on the pins which doesn't happen with hot air. You may also need a bit of braid / wick using the drag method.
