Logic Analyser Thread
4,058CR
I thought I'd start a new thread since the old one was getting somewhat off the point of the OP !
My cheap of cheap analysers hasn't turned up yet, probably another week or more I guess. Somehow today I've been distracted looking at the "Maker Bot - Thing-O-Matic" 3D printer which looks quite cool in it's own right. Anyway, I was looking through examples of what people had made* and I came across a case for the "Open Workbench Logic Sniffer" and off I went wondering what that was all about.
Well, I've no idea if the spec's are any good, but it's a 32 channel unbuffered, 16 channel buffered logic analyser for the princely sum of $50. Yes, $50 !!!
http://www.seeedstudio.com/depot/preorder-open-workbench-logic-sniffer-p-612.html?cPath=75
The software, however, does look kinda sucky:
http://www.sump.org/projects/analyzer/client/
I might be wrong, but I think the whole lot, hardware and software is open source though so maybe some way to do something about that?
Are the specs any good?
* I would guess the case had been made with a different make of 3D printer as it was clear acrylic that had clearly been laser cut, not built up in layers of ABS.
4,058CR
Actually, on the hardware page there's a link with a couple of videos and while the software's look and feel is a bit on the sucky side of things (it's Java, it's kind of to be expected!) it actually covers most of what you need:
Multiple triggers based on any mask of any of the channels
Same rate / buffer length
Cursor readouts
Al the main food groups, no?
trm
2,877CR
I think that started out on hackaday.com a couple of years ago and has clearly been refined as well as somebody agreeing to make a production run. The spec is pretty impressive. The software also look way better than it did when I first saw it so I'd guess it'll probably carry on improving now that you can buy the ready made board instead of hunting down a specific (no longer produced) Spartan dev-board and the user base grows.
As for replacing the UI, the comms protocol is serial and documented here
as is the VHDL for the LA itself.
One of the very nice features is the sample depth: even when using 32 channels you've got 4/6k (I suspect they'll upgrade from the current 4k depth to the max 6k with a future code upgrade for the FPGA) samples whereas the Intronix only has 2k per channel regardless of sampling rate (the Intronix does do some form of compression on the sampling - I suspect only storing transitions and not every sample) so I don't know how the actual bench test result would compare if the OWLS stores a sample at every interval, but whatever it's still $300 cheaper!
Plus you seem* to have got all of the code behind the system so you can hack away. Add state change sampling, optimise the code a bit to up the sample rates and so on. Probably quite an interesting way to get into VHDL.
* I say seem as the original sump.org page doesn't quite match what the retail outlet is saying so I don't know if the project has been forked as the hardware you can buy is closed source.
4,058CR
It's certainly interesting. I need to let the dust settle on all my recent household stuff (quite literally!) but I may be tempted afterwards...
