Logic probe question
Keithgeo
41CR
ok im a complete novice here with a logic probe but want to try get a start on learning how to use it. but i cant for the life of me figure out where to connect the thing, the alligator clips wont cleanly connect to anything without either falling off or touching something it shouldnt . where the hell do i connect these on a board! haha , the alligator clips seem far too big for connecting to stuff on a pcb. thanks
yorkshire_spam
765CR
Generally the clips are only there to power the probe, so how you connect them is not important. Because I only use mine on my test rig I fitted 4mm banana plugs and it connects directly to my test rig PSU.
A lot of PCBs/looms don't really have anywhere handy to connect them - you may need to hook a couple of cables onto the +V and GND of the psu and then connect the croc clips to them?
Keithgeo
41CR
ah that sounds easier alright, its a test setup im using it on myself so ill just do that. I didnt try that already because stuff i read online said you need to connect it to what you where testing so i assumed that meant the pcb.
yorkshire_spam
765CR
If I need to hook direct to the PCB I'm lucky... I mostly work on atari stuff which tends to have good voltage test points to clip to.
If it's a problem you should consider changing the clips to the probes style MonsterMug linked to - then you can (safely) hook them onto IC legs.
Keithgeo
41CR
I should be grand now that i know you can hook to the Ground and +5 on the Jamma PSU on the test bench, i thought you had to connect to the board somewhere, ill only ever be using it in the test setup. thanks a lot !
Keithgeo
41CR
Added two wires to ground and +5 and crimped some of those circle connectors on the other end. Connected the probe to those and it’s working now. I’ve no idea yet how to use it, but it’s lighting high low and pulsing etc now. Thanks a lot for the help.
Keithgeo
41CR
Monstermug said:
To use it you first need to learn about logic gates otherwise you just be poking around helplessly.
Yeh I’ve started to read up them alright, just need to get the hang of it. Getting it working was a first step I can now use it while learning the logic behind it. Keithgeo2019-05-13 19:22:08
Monstermug
1,807CR
I remember when I first bought my logic probe it was still unwrapped for 2 years before I finally picked up the courage to learn how to use it. When I finally did work it out, it was like a revelation! It was like how Neo saw the matrix
Keithgeo
41CR
Haha you think that’s bad I bought one last week, and was going through stuff there earlier and found one in I bought years ago and had completely forgot about. I obviously had intentions of learning before and forgot.
yorkshire_spam
765CR
To be honest these days I mostly use the probe to find dead inputs/outputs in conjunction with the schematics. If I need to dig much deeper that "dead or not dead" I tend to use a 'scope, logic analyser or comparator. (But for quite a while I just had a probe)
I got a cheap second hand USB 'scope, which is a lot better than my old Goldstar 20MHz "small" scope, and takes up a damned site less space than my Tektronic 7603. I also have a cheap USB logic analyser which is fantastic for the money!
(http://hobbycomponents.com/testing/243-hobby-components-usb-8ch-24mhz-8-channel-logic-analyser)
