Long term cabinet storage
Gaming Heaven
106CR
Not sure this is the right place so feel free to move the thread...
To my joy I have realised now that I have cleared some junk, I can store several machines in a sheltered area on my plot, it is under cover, not in a garage or shed, so there is no risk of rain getting on it but there is a little wind flow and also temperature wise it will be close to outside air temperature, perhaps very slightly warmer.
For when I run out of space in the games room I was thinking of storing one or 2 machines there. I could equally sell them and may also do that, so it could end up being short term storage in the end but it might be long term storage, eg until maybe I move house/get more games space etc.
my plan was:
- remove all pcbs and other easily removeable electronics where possible, [bar monitor chasis and transformers]
- seal any openings like grills with good tape
- use electrical spray to coat fuses, transformers, connectors ect to give them some protection from corrosion
- put some large silica sachets inside the cabinet
- buy a sofa storage bag and cover the machine fully and tie tightly at the bottom
- the machines are on castors so are raised from gound level and they are also very well varnished on the underside
thanks in advance!
obcd
3,830CR
Be carefull if you seal openings with tape. A lot of tapes have glue that hardens out after a period. If you remove it, the glue stays sticked on the cabinet and is almost impossible to remove without damage to the cabinet paint.
Silica sachets are good but can only absorb a limited amount of fluid. After that, they can become wet as well. You could put them in a plastic box with the top side open so that the water can't leak out if humidity becomes 2 high.
