Loosing focus
campbell87
56CR
Hi all,
I leave my cab on for about an hour, and it starts to go out of focus and get brighter. Any ideas why this could be? It's a K7000 series chassis
smarty
Ready Player One
1,305CR
I’ve found the original LOPTs in K7000’s to be prone to cracking before failure, most i’ve Replaced at this point fixed bad/losing focus problems.
Also check the focus pin in the neck board. Corrosion, bad solder joint etc.
campbell87
56CR
Thanks Smarty, I'll check it over when I've got some spare time. I've never had to do any work on it since I bought it, probably because I don't leave them on for long periods of time.
campbell87
56CR
hi guys,
I'm getting round to looking more into this, do i need to remove the neck board to check the focus pin?
If the LOPT is cracked, then would i hear any unusual sounds or would i just get the symptoms i'm seeing now?
thanks
urbanledge
95CR
take a look at it in the dark and you might see a blue arc.
Blue arc,weird smell smoke etc
tb2000
3,584CR
The original K7000 lopts crack around the focus pot (and the screen pot as well sometimes). The cracks are usually hairline cracks but they still can affect it, and as Grant says they can go internally as well.
campbell87
56CR
Hey guys,
I have inspected the chassis 25k7191. And it seems that there is a hairline crack just around the focus pot. I'm assuming this is why it's losing focus after 20-15 minutes.
Does anyone know where in the UK I can get a flybacks for this? Not had much luck so far.
Dan
campbell872019-10-08 19:55:09
