lopt arcing
grobda
1,061CR
got a little hinari traveller tv thats started arcing to the chassis from the lopt. can this be repaired or is it a new lopt/writeoff?
seems to be an inverted L shaped crack in the casing running down from the anode cap wire
PaulSwan
ZZZ
1,118CR
Cracked LOPT usually means you need a new LOPT. You could try removing the LOPT and resealing the crack but even that might not be enough to keep it going for very long.
Paul.
grobda
1,061CR
took the lopt out and found it wasn't a crack but just a molding line. was still arcing from it though. read somewhere you can tape them up so covered the area in electrical tape about 4 layers thick. put the lopt back in fired it up, it hissed at me once but then worked. im sure this is a temporary situation.
one odd thing it does now at power off is you get a few flashes at the center of the screen every couple of seconds that get fainter. last about 10 seconds. just out of curiosity anyone know whats causing this?
time to sell it
not really its going back on the shelf now its 'fixed' until i decide whether to bin it or fix it properly.
grobda
1,061CR
standard pvc electrical tape =~7kv (single layer) from what i read. i tested it for 5 mins out of curiosity then its back on the shelf. think its destined for the bin.
