I recently flicked on one of my jamma cabs with an original Konami (Stern labeled roms) Scramble.
There was a 'pop' noise and then I smelt the dreaded electrical burning smell. The game was on ok, but had no blue on screen.
I turned everything off pretty quick and then powered on again - but still no blue.
I had a look at the monitor today and it is just fine. Other games display blue just fine.
On to the Scramble board. I noticed that a transistor to the right / front of the connector looked like it had cracked joints. I bent them about a bit and re connected the cab and it was working ok. I played for a few minutes and noticed that the sounds were becoming quite muffled and in the end all sounds went really quiet. I turned up the pot and I can hear all sounds ok, except explosions.
I reflowed a bunch of caps and replaced all the radial caps around the sound section to no avail.
Usually when you turn the volume right up with the pot it is deafening, but this isn't that loud.
I checked the pot with a multimeter and it is good. Zero ohms to about 217.
Any ideas?
Any ideas?
