Low +5v advice
bones
1,628CR
Hi, before I just source and replace all the components in this circuit, can anyone logic out the most likely problem device.
This circuit when functioning correctly pumps out 5.67v, at the moment I am getting 4.9v at the regulators output pin. The regulator has the same input voltage as a good circuit producing the 5.67v. Any educated guesses ?20250217_194255.jpg
bones
1,628CR
It was without load, I have several of these power supplies to compare against, this unit came from a machine that was resetting whereas the PSUs with the 5.67v do not reset the machine. Just grabbed a regulator off of a good psu and that is only giving 4.9v ? So not the regulator I'd say.
bones
1,628CR
Ok stopping now, changed everything except the bridge and no change. If the regulator is 5.25v max then best I check the working units again. Confused as the bridge is putting the same voltage into the input of the regulator as the others. There are other voltages on the pcb but the only connection between them is the 0v line ugh
bones
1,628CR
It comes from a transformer at 8.11v hits the pcb bridge and comes out at 9.69v the off to the regulator. Seriously considering that the diagram doesn't match the pcb as the unregulated 5v is coming from the unregulated 12v circuit on the pcb so best I go to bed lol
