M58725P Ram query
Purity
The Oracle
17 (100%)
2,999CR
I'm working on a Cook Race (Burger Time clone) PCB, and I've done quite a bit of work on the both boards because of corrosion. There are two M58725P rams in particular that I've desoldered on the bottom board, replaced with sockets and 6116-2 RAM, as my understanding was that the M58725P ram is the same as 6116.
On power up I get random garage on screen. However if I replace the original ram in the sockets, the game *mostly* boots, although there are still issues with the game.
Is this a case that the 6116-2 is not fast enough?
RGP
Meeter & Greeter
2,039CR
If they are pin compatible then speed would be my guess.
I did a gauntlet 2 sound repair not long ago where use of HM6116-P2 was the required type, the 2 i pulled from the board have been tested and reused elsewhere with no issues.
[tube]TWVZPWldw5I[/tube]
obcd
3,830CR
Isn't there an extension after the number that corresponds to the speed? -12 would mean 120ns and -20 would be 200ns in such case. Sometimes the same chip is available in different speed options.
