Mad Battlezone Vectors
virtvic
The Cabaret King
21 (96%)
2,013CR
I got a Battlezone off of a member and it seems to work, except for a bit of mad random vectors flying around and some bits appearing / disappearing.
Is this a normal fault and how easy is it to fix?
I was thinking maybe the voltages as they are a little bit off, especially on the higher volts. +5v seems to be bang on?
I probably need to do a kit upgrade on the AR II and replace the big blue as well?
Equites
Chief Sheesher®
35 (100%)
3,329CR
virtvic - Im no expert but I believe Battlezone hardware is very similiar to Asteroids. The symptoms you mention sound like a PCB issue, but could be due to power. Have you checked your edge connector and the edge pins on the PCB?
Get a video up, there's some real techy guys here that can help.
Equites2011-02-28 20:36:32
virtvic
The Cabaret King
21 (96%)
2,013CR
The board had previously been repaired, so it should be ok.
I got the pinout from crazykong.com and the edge connector seems to be missing quite a few pins, but as the game does run, I presume they are missing on purpose.
I'll get the manual tomorrow and have a read...
I'll try and get a vid tomorrow, also.
darthbob1425
27CR
Don't worry about some of the pins not being attached to the loom. I have the same thing with my asteroids clone. The diagstep pin is empty and you use it as an extra test mode by attaching the pin to ground and starting up. I don't know if this is the same as on Battlezone but based on Equites comment seems likely.
Rob
Equites
Chief Sheesher®
35 (100%)
3,329CR
Dude the edge connector can cause lots of issues on these old Atari cabs, mine is shot on my Asteroids and I am going to replace it completely very soon.
Based on a tip from Martin, I made up a 'jumper' lead that goes from the AR test points into the PCB test points for +5v and GND. It meant that until I do not replace the edge connector my PCB is safer from being fried due to the AR sense circuit pumping up the volts due to bad resistance caused by dodgy edge connector.
As darthbob1425 said some pins will be missing related pins on the edge connector.
Equites2011-02-28 21:08:21
4,058CR
How random and does it make the game crash? Sounds like math box errors - something Asteroids doesn't have as it's not 3D. A video would help. I second that it does sound like a PCB issue.
OR, it could easily be caused by the interconnect between the main PCB and the Aux PCB. They're sh*te and don't last forever. Try giving the header pins a clean (a little wet and dry USED DRY and WELL out of the way of the rest of the PCB). The Red Baron down at the barn was initially resurrected from the dead just by doing that.
[EDIT] just to re-iterate, that's the header pins at either end of the connector that joins the two PCBs. NOT either of the edge connectors. Don't go anywhere near them with wet and dry or anything remotely like it.
guddler2011-02-28 21:34:22
DanP
Administrator
2,232CR
Might be worth looking at the connector between the two boards. Have a look at the pins, make sure theyre clean and that there are no cold solder joints. Then check the actual connector, are the pins ok, clean, etc. If it's not that you could also try reseating the mathbox 2901s.
Huh
Dan
virtvic
The Cabaret King
21 (96%)
2,013CR
Thanks guys - that sounds like a plan.
The game WAS working fine, when I first powered it up, but it died soon after. It simply wouldn't come on at all. Just a red led on both boards.
I pulled out the ARII, both boards and the power supply to inspect them all, and replaced them. It then came back to life again, but with messy vectors.
I'll clean the connecting pins tomorrow night and see how it goes. I'll also vid it if it's still loopy.
ps - It looks like it's had the sense mod done on it.
virtvic2011-02-28 23:08:47
P-Man
International man of mystery
1,273CR
Welcome to the world of owning a Battlezone.
In test mode, do you see a H L or T displayed? wacky vectors of 3d-world objects are all related to mathbox (aux) pcb problems. The pcb may be having problems because of interconnections to the AVG, or power issues, or heat issues, or socket issues. I've owned several battlezone cabs, wonder if you have one of my old ones :)
4,058CR
Let us know how that goes. That's definitely a math box error. "Low byte data" error. Cleaning the connectors may help. Guess we can take it from there?
virtvic
The Cabaret King
21 (96%)
2,013CR
I already cleaned / lightly sanded the connectors. They looked pretty clean and rust free anyway.
I'll continuity check them as soon as I can get in the ArcadeGarage again.
virtvic2011-03-03 23:03:02
