Yeah I know I can its just I don't want to leave any gaps on the back of the cab if Riley is going to play on it as you know kids, a jammie dodger or something would be shoved through the gap if I don't swap like for like lolsilverfox0786 said:you can either bypass the filter and get a kettle plug with switch or then buy an integrated one as you have or then buy the kettle lead plug and buy a separate filter as I usually do
Stevros said:Those things are nothing but trouble, I always remove them, can anyone tell me what they are actually for?
I presume they stop interference on the screen or am I wrong?
Cheers foxy I'll have a look asapsilverfox0786 said:
it nearly was bypassed as the filter comes out lol but I kept messing instead of the easy fix... which in this case wouldn't have actually solved anything lolguddler said:They're as much as anything about ensuring that the arcade machine doesn't cause interference with other stuff more than other stuff causing issues with the machine.
You've got to remember that back in the 80's you'd have had a room with potentially several hundred of these things on. I wouldn't have wanted to live anywhere near that lot if the filters had not been mandatory.
These days, when they go I tend to just bypass them but I do understand the issue of access here.
