I just sent a PM to a member on here who I am sure 'KNOWS THIS' ANYWAY as I have read his tech replies frequently but sometimes its just that thing you never thought of ??????????
but as I wrote it thought I might as well cut and paste it to you all TAKE CARE WHEN EXPERIMENTING !
paste....
don't know how technical you are or what equipment you have but heres a quick couple of tips to get a mystery board connected...……...
back in the 80s we had hundreds came to us new and used...…… but helps if they are at least partly or fully working ……….. goes without saying and a lot had joe bloggs oddball connects before jamma and electrocoin unified them on main games …………. tho dedicated ones still accounted for many
TAKE PCB and with a meter and eyes from ICs and main common rails pick out the GND & +5V .. sometimes if you can see on board volume its possible to track the 12v also and wire those
With 5v and gnd going on to the pcb ….if you have a scope feel down the tabs of the edge fingers ………. most of them will also now be 5v ?
where you get a wavy ac around 1v to 2.5v on 4 tabs that's the video out and can be next connected
its NOT important you get RED GREEN BLUE or SYNC in right places as they will all safely swap also add a GND to your video from a GND tho one near to the 4 video tabs mays also be a 0v video ?
if you get none of the above 2 statements you probably have a dead board ,,, just probe the Xtal area and any ICs legs to see if anything has logic pulsing...……. NO then give up or get digging
have video signal ………….. connect to a monitor you may now have some sort of image and swap sync with colour till you get a stable picture then swap colours till you get blue sky green grass etc
TAKE A PIECE OF WIRE and crocodile clip attached to one end and a 150 ohm resistor to the other end about 10 inches long, fold back the open end of the resistor to make it a bit stronger like a probe
CROCODILE clip to the GND at connector...…………. with the connector attached to the pcb just meter if you have a good +5v level on the 5v rail on pcb just to give it best chance of functioning adjust power supply up or down if necessary ?
the reason for the resistor on this wire?? is to buffer any erroneous voltage on a tab ie at the speaker positions or any other undefined tab?? it save a 'direct short' or sparking and 'cushions' the contact
touch each of the tabs you know by meter or scope are 5v THE ONLY ONE WHICH WILL RESPOND IS COIN IN (or perhaps coin 2 in) JUST EDITED TO ADD 'test' and 'service credit' may also respond WHERE INCLUDED? continue and the next to respond (if you now have a credit) and the only one will be player one start...……then with multiple credits player 2 start can be located also………. …
again if you don't have a near working game at this point its check for faulty areas ?? or give up
then if you have a visible game LEFT RIGHT UP DOWN FIRE JUMP etc should with patience be obtainable ADDING WIRES TO YOUR CONNECTOR AS YOU PROCEED ……………………. with a near or fully operational pcb you will have ALMOST made an adapter
add if known 12v then get a small speaker and you can maybe trace the sound tracks from amp ics or that area and the few remaining unused tabs try the speaker one end to GND and one to a fairly obvious vacant tab ……with a game in play and the possibility the sound functions the speaker can be attached // other unused tabs will be coin meters/ lockout coils or just not normally used ! and leave them empty..... no wiring needed ……………YOU MAY KNOW THIS ALREADY BUT SOME ON HERE WILL NOT so this is for them with confidence to try get repairing or testing . ALWAYS THINK SAFE you cant see electric with your eyes…no matter how small the voltage
. doesn't always work out but its easier and better than guess work which may damage a good pcb
69er2020-05-03 12:01:53
paste....
