MAME build help
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
Hi Guys
Im nuilding a MAME PC as i dont want to use these rubbish XXXX in 1 systems
now here is what i need to know
im using a Ultimarc ARcade VGA and a Ultimarc Video Amplifier to get my 15Khz signal
All seems ok there
what i need to know is what is my correct resolution to use to get aMTC9000 Monitor going
is it 640x288 or something else im not sure
limpy
132CR
if you use groovy mame there is an ini file to select your monitor type so you don't get break monitor resolutions.
for best results I use calamity drivers with arcadevga but results will be different depending on what arcadevga you have
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
strykr said:
Using an arcadevga without a jpac your gonna need a video amp I think Sarj.
https://www.ultimarc.com/avgainst.html
Yes i have that.
Hurray Banana said:
Here's a list of resolutions that I know sync from windows at 15Khz
632x264
640x288
640x240
256x240
335x240
512x288
512x240
288x240
368x240
352x288
384x288
I use quickres to select resolutions, works on xp don't know about win7
https://www.ukvac.com/forum/data/uploads/1527/quickres.zip
im using quickres it comes installed as default with teh ultimarc drivers
what i wanted to know is what is the correct default resolution for the Hanty Monitor
im also usign teh quick res app that switches the res automatically when you select a game so this is relly just for when im in windows mode
big10p
Coins detected in pocket!
6,082CR
I have my default res set to 688x512i on my MTC9000, just so I can fit a bit more stuff on screen in Windows. MaLa dialog boxes etc. won't fit on a 640x480 display. I use Calamity's excellent CRT_emudriver and GroovyMAME.
Presumably you're just asking about a default Windows res as surely you'll be playing the actual games at native res, where possible?
big10p2015-09-20 10:58:29
