Mame cab advice please?
paulcan69
946CR
In addition to my dedicated cabs I want 2 mame machines (horz and vert)
One will be golden tee which I will build now with a half decent pc, and later I will use my vert goliath mk1 and build (using a not so go pc) for all vert games.
Right the time is here to mame my Golden tee (I'm doing another control panel for it) It will have 2x sticks 6 buttons per player and a golden tee trackball in the middle - That's it!!! Not 400 sticks and spinners just the above.
I want to play centipede and marble madness, missle command etc.. which may at a later date make me want the real cabs. (knowing me it will) The only trackball game I've played in the last 10 years is golden tee
I have a 3ghz P4 1gig of ram and a 256mb geforce * (can't remember which)
I have an otipac for the trackball, a j-pac and an early-ish arcade vga card.
I'm thinking XP but will shell straight into something when done, and don't care about CHD files.
My question if you would be so kind to answer:-
Which is everyones fav frontend, and how can I setup the mame resolutions quickly.
I've heard of a mameres tool, just would like you experiences with this if you may, or if you found something better?
Lastly (for when I do the vert mame cab) which is a better frontend for vertical games as I've been told one of them has an easy way to pick all vert games and remove any horz games from the list.
Is anyone aware of this?
Many thanks in advance to any help to any of those questions.
Paul.
DanP
Administrator
2,232CR
Hi Paul, my favourite front end is ArcadeOS, which is very old now and only really meant for Dos but I like it's old skool 8 bit feel. I just wanted something that worked to get you quickly into the game you want to play and it fits the bill nicely. The other main advantage of using Dos is that you can just power it off, no need for a controlled power off of the pc before the cabinet.
Another option I've played with is Advmame which has a live cd option (u boot off a Linux cd) info is here:
http://advancemame.sourceforge.net/cd-readme.html
I'll be interested in what you come up with, I really should update my old Mame pc's from the old P3's running mame 0.36
Dan
Mini
7CR
I used Mala with the 'Retro GUI' theme.  I use it on a PC monitor but it's equally good with arcade monitors and is designed to work well with low resolutions.  Windows is totally hidden.  All you see is the POST screen on bootup.  When the front end is exited (by holding P1 left and P1 Start) the PC automatically runs the shutdown.exe file.
I also use Advmame, in a Space Invaders cab.  I have it booting from a CF card however as it's much quieter than a spinning CD drive.  Like DanP says the big advantage is that it can just be powered off instead of shutting down, and is pretty easy to configure as it's just one text file.
paulcan69
946CR
Thanks guys, I will research both and do a simple setup of both and see + and - points of both
Ta for a starting point.
I've had a mame cab before but was just windoze xp with mame32 (and newer GUI version)
but that had a 22" svga monitor (just not the same)
