Mame hotkey
RygarR
412CR
Evenin All
Just picked up a jpac and swapped it with a partially working example in my MALA / MAME cab. The new one seems to be working well, with all the hotkeys functioning. However, if I press down on P1 Joystick, it opens the master volume control., which is a bit distracting. I have a fairly recent version of Mame (1.49 or something), but haven't needed to tinker with the tab since much simpler times, and don't know how to sort this out. Any advice welcome.
A
ZedEx48K
8-Bit
1,421CR
You could just open up the mame config (ingame with tab) and make sure down is set to down and also just set the volume (default is ` next to 1) again or select it and press delete to clear it, problem solved
RygarR
412CR
Good call ZX
Never thought of checking down itself. Doh! I'll give it a whirl tomorrow and see what happens.
Cheers,
A
RygarR
412CR
Turns out that MAME no longer has a hotkey for master volume control, which is what was confusing me. It's all done with the sliders these days. It seems I should have been looking at the open console command. God knows how that got messed up. Must've been the kids :)
